996 GT2/GT3 Forum 1999-2005
Hard start when hot?
Old 02-17-2017, 09:02 PM
LIS
LIS's Avatar
Default Hard start when hot?
Anyone else run into this problem? My car starts and runs just fine when cold, but takes a bit of time to catch once it's warmed up. Mechanic said something about a check valve in the fuel pump, but I haven't found a reference to anything that's replaceable.
Thanks!
Larry
Old 02-18-2017, 04:06 PM
tgavem
tgavem's Avatar
Not sure if this will help, but the 997 has a know issue with the main power cable going to starter and insulation breakdown which has the same symptoms.
Old 02-20-2017, 10:55 AM
LIS
LIS's Avatar
Thanks, I'll check that. I've also seen reports of similar symptoms related to the starter itself and to a valve in the EVAP system. I'll plug in my durametric and see if any codes have been thrown.
Old 02-20-2017, 11:39 AM
Vanos13
Vanos13's Avatar
Is the problem correlated to refueling? I had a hot start after refueling issue that was fixed by replacing the evap purge valve in the engine bay. Easy job.
Old 02-20-2017, 12:22 PM
LIS
LIS's Avatar
Don't think it's related to refueling. It seems to happen every time I get the engine hot then turn it off and let it sit for a while. I don't mean track HOT either, just driving for 10-15 minutes gets it warm enough for this to happen.
Quick Reply: Hard start when hot?
