996 GT2/GT3 Forum 1999-2005
BBS E88 sizes and tyre sizes
Old 01-17-2017, 01:07 AM
  #31
mooty
GT3 player par excellence
mooty's Avatar
Received 5,481 Likes on 2,269 Posts
Originally Posted by spiller
Is the 9/12 combo OK with a 245 up front and a 295 on the back? I know Luis said it fits, just wonder what the dynamics of the vehicle are like. I guess you could run a 235 on the 9 also to keep OEM sizes.
295 on 12" is really stretched
Old 01-17-2017, 01:22 AM
  #32
spiller
spiller's Avatar
Sorry I meant 11.5. I don't care for stretch. 245/315 fits really nicely on OEM I find
Old 01-17-2017, 08:58 AM
  #33
LuisGT3
LuisGT3's Avatar
I'm not a fan of stretch either. There is no stretch with my 9 and 11.5 set up. (PSC2)
Old 01-17-2017, 09:20 AM
  #34
mark996GT3
mark996GT3's Avatar
They look spot on Luis, can you confirm the rim and tyre sizes you are running for me? Is it exactly as Mooty said on page one? Sorry if I should be able to work it out, I just want to be clear on the best sizes & options....thanks everyone
Old 01-17-2017, 09:57 AM
  #35
LuisGT3
LuisGT3's Avatar
Yes. Exactly as Mooty stated with stock size Pilot Sport Cup 2's.
Old 01-17-2017, 12:09 PM
  #36
spiller
spiller's Avatar
Fitment looks perfect Luis, thanks for the pics. It looks like there is still a little room under the front fenders for a 245/40 too (I have some NT01 that I want to burn up).
mark996gt3, I have no experience with these particular wheels but camber does affect wheel fitment, I'm not sure what camber Luis is running in the pics above but most guys tracking their GT3s have somewhere between 2.5 and 4 degrees negative on the front.
Old 01-17-2017, 11:58 PM
  #37
Mr. Ayo
Mr. Ayo's Avatar
Originally Posted by mark996GT3
Great thanks for all the advice, cheers, however, a little peturbed by Mr Ayo's incident....that was using a 9 inch front, yet other people say it fits fine and no contact? Mr Ayo, were these the same wheels and when they were fitted, was there any contact on testing? Or did it only occur at the track day?
I'm running this setup on the front: (from Mooty)
0288120 1.5" and 7.5" barrels 9x18 et 42 with 245
Stock suspension, around -3 camber. Every car is different apparently.
Old 01-18-2017, 12:08 AM
  #38
Mr. Ayo
Mr. Ayo's Avatar
Originally Posted by powdrhound
Curious, what offset were your 12s? As far as the fronts, I run 10" fronts with 275s and don't have any rubbing issues. Ride height is 102mm and fender is tightly rolled however. My car is a 6wide body but front end is identical to 6GT3.
The rears used 1.5" lip and 0288274 face, and whatever barrel size to get to 12. Also was running 5mm spacers.
I've since removed the spacers and went down on the barrel size to get to 11.5 and have no more issues.
Old 01-18-2017, 01:42 AM
  #39
911mhawk
911mhawk's Avatar
Thanks for the pics, I was on the fence over gold vs. silver centers.
I have a set of fresh PS2's in 245/315 for the street that need wheels.
Anyone know if the OZ alleggrita in 18 fit over 380 brakes?
Hopefully someone can chime in no since I got rid of a perfect gunmetal set in GT2 size.
Old 01-18-2017, 01:52 AM
  #40
Dervish
Dervish's Avatar
Do 245 fit on 8.5" fronts?
Old 01-18-2017, 02:55 PM
  #41
spiller
spiller's Avatar
Yep, 245/40 is fine on OEM wheel, rubs the arch liner at full lock but not a big issue.
Old 01-18-2017, 06:38 PM
  #42
powdrhound
powdrhound's Avatar
Received 1,721 Likes on 1,003 Posts
The offset was your problem, not the 12" width. When you ran the 0288274 centers with a 1.5 lip and a 10.5 barrel, you had offset of ET 74.4mm. A 5mm spacer made it ET 69.4mm. A 12" with at ET 61-64 would have worked. When you swapped the barrel to 10", you ended up with a 11.5" ET 61.7mm wheel which is the correct offset.
changster123 (10-22-2023)
Old 01-19-2017, 03:41 AM
  #43
mooty
mooty's Avatar
^ right on, i didnt realized he ran 274, tnat's not a common center for 996 narrow body, also produces shallow dish outter lip.
Old 01-19-2017, 03:48 AM
  #44
Mr. Ayo
Mr. Ayo's Avatar
So what's the 274 center for? My shop was told repeatedly by BBS that I had a correct setup.
Old 01-19-2017, 04:17 AM
  #45
mooty
mooty's Avatar
274 is often used for cayman. it can be used for 996, but it's not as common
Quick Reply: BBS E88 sizes and tyre sizes
