euro gt3 seat side mount question
Hey all, quick question for the seat gurus. Josh installed some euro buckets in the car before I bought it back, and although I used to not be a fan, they are really growing on me, so much so that I just bought a used pair in perlon that I plan to install (I think it will look better than black leather against the natural brown interior).
The seats are currently mounted with the oem Porsche side mounts, which as you all know, only have one rear hole per side for mounting the seat, meaning there is no "rake" or tilt adjustment (at least not without drilling new holes and trimming the plastic of the seat belt hole trim).
So, are there any non-oem side mounts that work just as well with the oem bucket seats, have the attachment point for the harnesses and belts, but also have an extra hole to provide some tilt adjustment? If so, that would be perfect as I'm 6'4" and would love just a tad more rake. Thanks!
Brey- Krause brackets?
http://www.bkauto.com/mobile/Product.aspx?id=37515
That's the first one I grabbed from their site and I know there are a few different ones so look closely.
Thanks for that lead. I checked out BK Auto and the problem I see is that literally every single one of their mounts lacks the "outboard" seat belt/harness mount that is featured on the oem mounts (the bk mounts have the inboard mount only). These mounts assume that you will be clipping in your harness belts to a rollbar or the stock seat belt attachment point on the outboard side. Problem is, you can't "clip in" with the schroth belts that are designed for the gt3 seats, since they are "eyelet" style. I'd like to maintain the stock mounting locations since the harnesses were designed for the loads exerted only when in those locations.
I used something like this...I'm in the UK but I sourced it from the US on eBay.
http://www.ebay.co.uk/itm/282050254357
and also using an aftermarket sparco type slider gets the seat nearly an inch lower than using oem slider.
would love to retain the oem slider...I have sparco and recaro and they just don't seem to work as well. Will probably just mount what I have to the floor and see if that helps a bit. As things currently "sit," the top numbers on the tach are obscured by the top of the steering wheels so I'd love to get just a tad lower. I already have the bk adapters so I might as well mount to the floor and see how I like it. If I don't I'll probably just drill another hole in the side mounts on the driver's side.
Congrats on buying back the car Scott. I have the factory Perlon buckets in mine and find them better than the leather version. They are just perfect. I will take a look over the weekend and see how mine are set up. The car is at the hangar, so I can't look at it now. I have the sliders in tact and there is plenty of headroom with helmet on.
