Coolant line failure on track
Wanted to share what happened to me this past week-end. Finally decided last year to get my lines pinned while other things were being worked on. I was at Chuckwalla this past week-end and a line failed on me. Ruined my week-end and obviously inconvenience many others. Let me tell you... I went out there to help clean my mess and it is no easy or fun task. It was brutal!
After inspection, my mechanic found the line that "popped" and it turned out it was one that was not pinned. The line that failed for me is the line going into the oil cooler as shown in pictures below. What I'm wondering now is this... Did the shop that did my pinning missed this? Or should I have specifically told them to pin ALL since this specific line doesn't go into the engine block?
So here we go again... engine drop, inspect everything, make sure ALL lines are pinned and put back. My wallet is crying
Crap! That hose from what I hear is the most common one to pop, it's hidden behind alternator.
Is it pictured here? I think it is:
http://sharkwerks.com/porsche/techni...urbo-cars.html
It almost looks like there's a bolt head in that last picture???...did they pin that fitting and just not execute the pinning correctly?
There should be 8 fittings on the 996 (only 6 on a 997). The ones that are most commonly overlooked are the ones attached to the lower oil cooler housing and the one hiding behind the power steering pump. That's pretty odd that that particular one would have been missed.
It requires more work to do than the easy ones?
That's one you wouldn't notice they didn't do?
Maybe it wasn't done on purpose or charged?
All sucky answers...
At least you'll know the car is tight going forward.
Coolant hoses
Andy was able to stop by the dealer and point out the hoses that sometimes go out. The are indicated with the yellow arrows. I got mine replaced as I have about 41K miles on those hoses. Didn't want to take a chance if we do "One Lap of America" next year.
I have a mix of some welds and pins.
Goad she's coming back together and glad you replaced those main hoses. She's going to be trouble free for many many miles to come.
Basic Sponsor
I've had a few of these burst on me in different cars, one of them while on track. Visually it looked almost as if the whole thing shifts into the motor mount edge causing it to burst but can't be 100% certain. Needless to say I replace it now anytime the engine comes out.
Instagram :Swine11 | TitanMotorsports
Swine11 ReBoot - 964 / 993 Shift Boot Trim Panel
2004 996 GT3 | 1986 Carrera 3.2 (future Keen Project) | 2016 Cayenne Diesel
i've seen those larger hoses pop off a few times. Usually the metal clips fatigue and then the hoses just pop off. We safety wire all those coolant fittings on the race cars. It's a easy job that can be done at home, it's just a little time consuming to properly safety some of them.
