996 GT2/GT3 Forum 1999-2005
TRW PCCB Brake Pads
Old 03-04-2016, 10:14 AM
gclasse
gclasse's Avatar
Default TRW PCCB Brake Pads
Has anyone of you tried the TRW PCCB pads?? I saw them on Pelican Parts at a great price! Any feedback will be appreciated.
Old 03-04-2016, 05:18 PM
lax01
lax01's Avatar
I do not see any pads on Pelican's site for PCCB: http://www.pelicanparts.com/catalog/..._pg1.htm#item0
Where do you see them?
The only TRW pads I see say "Not for Carbon Ceramic usage"
Old 03-04-2016, 06:05 PM
993GT
993GT's Avatar
I haven't but I would trust them and thought about some for street use on my car(I am on iron discs now)...TRW is the major chassis parts supplier for 996/7
Old 03-04-2016, 10:46 PM
gclasse
gclasse's Avatar
Default Gt2 PCCB brake pads
Check the GT2 brake pad options
http://www.pelicanparts.com/catalog/...BRKPAD_pg1.htm
Old 06-10-2016, 01:35 PM
pinternational
2nd Gear
pinternational's Avatar
just an FYi...
https://www.ecstuning.com/ES2581450/
https://www.ecstuning.com/ES2581428/
I just bought some to replace mine, which are at 50%.
I'll let you know how they go!
Old 06-10-2016, 01:51 PM
993GT
993GT's Avatar
^those are 997 pads
Old 06-13-2016, 10:47 PM
TomGT3
TomGT3's Avatar
I purchased a set for the rear 2 years ago. I never used them.
I'd be happy to sell them to you for 1/2 of the best price you can find including shipping.
I also have a set of new rear OEM pads. I think they are P50.
Still have the box with part number.
Old 07-02-2016, 10:30 AM
993GT
993GT's Avatar
I just bought/installed the OEM TRW pads for street use, tired of PFC scream...still have good bite but zero noise and smooth when aggressive braking on cool brakes...because OEM
#'s
TPC0091 front
TPC0994 rears
Old 07-18-2016, 07:37 PM
chawch
3rd Gear
chawch's Avatar
The ECS parts list the TRW pads for GT3 and Turbos. Can they be used for my 05 C2S with PCCBs? Aren't all PCCBs have same caliper size and rotors?
Old 12-09-2016, 11:24 AM
black04
black04's Avatar
Default How did the TRW PCCB Pads work out?
???? How did it go with the TRW PCCB Pads ?????
Originally Posted by pinternational
just an FYi...
Old 03-01-2017, 06:08 AM
kamc
kamc's Avatar
Originally Posted by black04
Hi
How did you get on with the TRW???...
Old 03-01-2017, 11:31 AM
kamc
kamc's Avatar
Hi
I have been in touch with Technical TRW in the UK.
They advise these pads are not to be used on PCCB brakes!...
Old 03-02-2017, 03:23 AM
black04
black04's Avatar
Default Which ones?
Originally Posted by kamc
Hi
Which part number?
Did you get that in writing? Seriously.
Old 03-02-2017, 03:46 AM
kamc
kamc's Avatar
Which part number?
Hi, yes spoke to technical support and explained this link as I have never seen any TRW in the UK offered for PCCB.
His email reply below, GDB1817 is a fitment for the 997 Turbo front pads.
Not sure if the links above are from another source and are correct, did contact ECS - no reply.
"Just researched the matter and I cannot recommend the use of the following parts numbers with your Carbon Ceramic brake discs.
Front
GDB1817 - Does not include aluminium counterweights
GDB1863 - Includes aluminium counterweights.
Rear
GDB1792
As far as I am aware the brake pads you require are NOT available in the aftermarket."
ZF Aftermarket
TRW Limited, Aftermarket Operations
Redwither Road, Wrexham Industrial Estate, LL13 9RD, Wrexham, United Kingdom
Old 03-04-2017, 12:22 AM
Backmarker
Backmarker's Avatar
$10k rotors/axle. I like OEM guys, not worth the risk.
Quick Reply: TRW PCCB Brake Pads
