996 GT2/GT3 Forum 1999-2005
TRW PCCB Brake Pads
Old 03-04-2017, 02:53 AM
kamc
kamc's Avatar
Originally Posted by Backmarker
$10k rotors/axle. I like OEM guys, not worth the risk.
my same thoughts!
Old 03-19-2017, 10:12 PM
Fecotrentini
Fecotrentini's Avatar
I bought and installed the TRW pads from ECS on my 997TT. So far so good, did more them 100 miles and 0 problems so far.
Pads are identical the oem that I was using..
https://www.ecstuning.com/ES2581450/
https://www.ecstuning.com/ES2581428/
I don't think ECS would sell this as PCCB Pads if they were not for it..
Old 03-20-2017, 12:50 PM
kamc
kamc's Avatar
https://www.rexbo.eu/trw/brake-pad-s...b1792?c=100030
Old 03-20-2017, 01:29 PM
Fecotrentini
I've seen this information on other sites after I had bought and installed TRW pads, trusting only on ECS information.
What I don't understand is why they are working like oem on my car? My car brakes like it should brake and it there is no scratch or damage to the rotors at all..
Old 03-20-2017, 01:38 PM
kamc
kamc's Avatar
All sites in the UK seem to say not for PCCB. I even contacted TRW in Germany and the same.
No idea!...
Old 03-21-2017, 11:55 AM
black04
black04's Avatar
Default Some TRW Pads are PCCB, but not all.
No idea!...
What Model or Part Number are you referring to? There are apparently PCCB and non-PCCB pads.
Old 03-21-2017, 12:01 PM
kamc
kamc's Avatar
997.1 Turbo , mine has PCCB.
Front: 997 351 948 02
Rears: 997 352 947 02
Old 03-21-2017, 12:25 PM
black04
black04's Avatar
Default TRW PCCB Part Number
Sorry, my question is, "What is the TRW Part Number? (for PCCB and non-PCCB pads, if available)"
Old 03-21-2017, 12:29 PM
kamc
kamc's Avatar
As noted on many web sites, not for PCCB;
Front: GDB1817
Rear: GDB1792
Old 03-22-2017, 07:40 PM
black04
black04's Avatar
Default Correct part number for TRW PCCB Pads
Originally Posted by 993GT
I just bought/installed the OEM TRW pads for street use, tired of PFC scream...still have good bite but zero noise and smooth when aggressive braking on cool brakes...because OEM
#'s
TPC0091 front
TPC0994 rears
Looking at the TRW online catalog, I believe it should be...
TPC0991 Front
Correct???
BUT YOU DON'T HAVE PCCB rotors. Why have you posted this information on this thread?
Please delete your posts.
Thank you for your consideration.
Last edited by black04; 03-23-2017 at 04:21 AM. Reason: The quoted poster is an idiot
Old 03-22-2017, 08:26 PM
black04
black04's Avatar
Default 997.1 Turbo PCCB Pad
Front: GDB1817
Rear: GDB1792
TRW UK website also states that those pads are not for PCCB
Old 03-22-2017, 08:47 PM
black04
black04's Avatar
For the record....
What is the TRW Part Number on the box your pads came in?
Regarding your question "...why are they working like oem...?"
Answer: Only hard or extended use of non-PCCB pads will damage PCCB rotors.
Old 03-25-2017, 11:16 AM
matthew_brady
matthew_brady's Avatar
Not to hijack this thread, but has anyone used these Akebono pads with PCCB rotors? I contacted ECS and they didn't have an answer for me last night (might have one by next week, they said).
They're listed as being "Only for vehicles with PCCB brakes (yellow calipers)" but I don't know whether this means they simply fit the calipers or that they are compatible with the ceramic rotors.
Old 03-25-2017, 07:39 PM
Jferrante
Jferrante's Avatar
i have rsc1's with a bunch of life if anyone needs em
Old 03-27-2017, 04:16 PM
matthew_brady
As a follow up to my post above, I received confirmation from ECS as well as two other suppliers of the Akebono pads linked above, and all three said these Akebono pads ARE compatible with PCCB brakes, including ceramic rotors. I'll try to remember to update the thread once I put them in and try them out.
Quick Reply: TRW PCCB Brake Pads
