Toolkit contents 996 GT3
US car. Mine looks the same as yours but I'm not the original owner. When I saw the earlier posted picture I thought I was missing the safety triangle, pressure gauge and first aid kit but didn't consider that the contents could be different by country. Any original USA owners please post a list or picture?
I want a red tow hook!
Right, North America specification cars have different 'kit'. I will double check but the contents in SJJ28's photo look right.
Not shown in that photo
- wheel lock socket (an adapter for the anti-theft splined wheel bolts)
@spiller Here are a couple of pics of my setup, as promised
In situ
Above is with the false floor in-situ. Note the "cut-out" in the front to allow easy removal and where the foam insert is just visible. The curved part of the false floor fits snugly against the curved front corner of the compartment. You'll note the luggage compartment lip is NOT visible as the false floor is resting on it.
Above image with the false floor removed to show orientation when in-situ. Note front corners are curved and rear corners are more like cut-off angles.
Hope this helps!
In situ
Hope this helps!
Looks like the very front lining where the trunk escape handle is located is: 996 551 045 11 A31 (black) front cover - Porsche; trunk trim panel, lining black. Available from Porsche and there is one on ebay as of 31 Oct 2023
Rear section lining over fuel cell is: 996 551 051 22 A32 (black) rear cover - Porsche; trunk trim panel, lining black; trunk front cover. Available from Porsche and there is one on ebay as of 31 Oct 2023
Tool Tray Cover/Panel: part number ?
I'm checking my parts schematic now and I assume you are looking for the normal GT3 black trunk carpet.
