996 GT2/GT3 Forum 1999-2005
A lap at the Nurburgring with a 6T3
Old 07-20-2015, 11:14 AM
Joe [FRA]
Joe [FRA]'s Avatar
Smile A lap at the Nurburgring with a 6T3
Hi there,
A quick share from France... more precisely from Germany, further to a trip to the Nurburgring, in order to "introduce" the 996 GT3 to this fantastic track.
If you have 8"40 to loose, you can have a look to "my" video (not fantastic, but really enjoyed the ride... even if I'm not faster than with my Opel Speedster n/a) :
https://youtu.be/dxmVEoMEs54
Then, if you'd like to enjoy a real great video, take a look at this one.
I gave the wheel to a friend, who usually drives an R8 v10, during VLN (endurance series) races at the Nurburgring.
He was discovering the car (very first with a 911 by the way), and promissed not to scare me too much.
Even if he felt slow and safe... it has been a great moment for me, I'll let you imagine
https://youtu.be/rWj8yyuRPaY
Cheers,
Joe
Old 07-20-2015, 12:31 PM
Burger
Burger's Avatar
Old 07-20-2015, 01:11 PM
4porsh
4porsh's Avatar
Good stuff.
Your friend seemed to feel comfortable with your car, even though it was his first time in a 911. What did he think of your GT3?
Old 07-20-2015, 02:00 PM
porschedog
porschedog's Avatar
wow!!!! That was great! Thank you for sharing. My "Ring" experience so far involves my PS3 and a racing simulator/Sparco seat contraption (usually with a dachshund in my lap)
Old 07-20-2015, 03:29 PM
JarmoL
JarmoL's Avatar
Here's one lap of mine. Car is 996 GT 3 mk1. Timing and speed are from Aim solo.
Old 07-20-2015, 11:36 PM
christallon
christallon's Avatar
Thanks for sharing guys! Your friend picked up the drive quickly. Awesome. Jarmol, great driving there. I am installing my cup wheel over the next few weeks. I love that wheel! Cheers!!!
Old 07-21-2015, 05:59 AM
Joe [FRA]
Joe [FRA]'s Avatar
Originally Posted by 4porsh
Good stuff.
Yes he did enjoy
He wrote his feedback, but in french lol (see hereunder for french speaking (Canadian ?) guys )
The car is full stock, with street tires (Michelin PS2), and a "normal" wheel alignment setup.
In short,
He dislikes :
- driving position, with the wheel almost not adjustable (contacts between knees and wheel)
- back "orientation" (as the seats are not adjustable at all)
- gearbox ratios too long on the road (during the "morning dry run" on public roads)
- when releasing throttle pedal in curves, on the road, body moves are impressive (LSD impact)
He loves :
- engine, especially over 5 000 rpm
- drivetrain precision
- drivetrain reactivity : perfect if you're perfect, but "over-reacts" when unprecise or hesitating (wheel or throttle correction are causing immediates and "visible" reactions)
- suspensions are hard enough to limit rolling effect, but not too much to make the car hard to drive on the wet (according to him, but only drivent in dry conditions)
- Traction is perfect
- Braking is perfect, even if street tyres are "not enough" to really take advantage of the brakes
- Rewarding to drive : perfect driving = predictable and perfect body reactions... but the opposite seems to be true also
Petite prise en main sur la route :
Allez je commence par la vrai seule critique, la position de conduite (du moins pour mon 1m83), le baquet est à mon goût un peu trop incliné vers l’arrière mais plus gênant c’est la position du volant que j’ai très bas et loin du corps qui m’a vraiment déçu :|
Ce dernier n’est pas réglable (les 2 cm de débattement en hauteur et pas de profondeur sont « une mauvaise blague ») et il touchait légèrement mes cuisses en étant débrayé et pour la jambe droite au talon pointe.
Niveau moteur, la sonorité est juste magique par contre il demande vraiment à être tenu dans les tours pour profiter de son potentiel.
Une fois au-dessus de 5000 ca pousse très fort et l’aiguille s’envole jusqu’au rupteur, miam miam :34:
Par contre l’accouplement à une boîte longue est surdimensionné pour la route (pour le ring c’est autre chose) et on se re-trouve à faire du 1-2-3 (et filet de 4 pour pas abusé trop non plus) en permanence.
Niveau comportement, le train avant est très incisif quand bien chargé et perd fortement de sa précision (et de son retour) à la remise des gaz (mais bon typique sur les Porsche en moteur AR non ?). La voiture réagit à toutes les impulsions immédiatement, ce qui peut dérouter quand on devient un peu approximatif.
L’amortissement est ferme mais pas inconfortable, sur les petites routes en bon état du coin, j’ai trouvé ca au top ! Ca prend un tout petit peu de roulis mais juste ce qu’il faut pour être sûrement encore bien sur le mouillé et on est super bien maintenu dans les beaux baquets et bien connectés à la caisse.
Sinon ca freine très fort et les pilot sport sont plus que suffisant pour se faire plaisir.
Joe me fait essayer le comportement au lâcher de pied légère remise de gaz à la corde, c’est vrai que les mouvements de caisse sont surprenants d’amplitude.
Sur le Ring :
Après un petit moment d’hésitation (c’est quand même les Touristenfahrt, je ne connais pas vraiment la voiture…etc), j’accepte la proposition très généreuse de Joe car vraiment trop curieux de voir ce que ca donne et parce qu’une occasion pareille ne se présente pas tous les jours !! :47:
Devant nous beaucoup de monde au départ donc j’ouvre en grand histoire de passer devant, oh là là ca marche vraiment bien cet engin, allez on va freiner prudemment sur l’arrivée de la Hohenrain Schikane pour pas faire regretter à Joe sa BA dès les premiers mètres. :devil:
On a pas mal de trafic si je me souviens bien jusque Schwedenkreuz mais je peux me rendre compte que les train avant est super précis au freinage en entrée / placement et super efficace, mamamia un vrai régal. Les pilot sport sont quand à eux dépassés par la puissance de freinage mais ce dernier est parfaitement dosable et un vrai régal au toucher. :35:
Je trouve l’équilibre au fil des virages vraiment parfait et la traction incroyablement efficace pour des pneus « de série ». Certes le train avant flotte à la ré-accélération mais rien de trop désagréable je trouve. Et c’est vrai que la voiture ne doit pas être conduite à moitié, soit on est sur les freins (même légèrement pour appuyé le train AV) soit en train de chargé la train AR à l’accélération, je ne l’ai pas vraiment ressenti, mais je pense que les phases de flottement/roulement doivent donner cette impression désagréable / « conne » dont on avait discuté avant l’essai. Pareil pour les corrections, ca se fait au mm et quand tout est fluide c’est un vrai délice de sentir la voiture réagir tout de suite. Par contre trop de (sur-)corrections peut mettre le doute sur le comportement de l’auto : j’ai eu 1 ou 2 fois cette impression sur la route mais pas sur le ring.
Sinon c’est super sympa aussi de pas avoir à regarder le rétro AR et de voir les voitures devant se pousser sans même faire un appel de phare. :8
Voilà le tour est déjà finit et je serais vraiment bien reparti de suite pour un 2ème en attaquant plus (pas besoin de se poser de question sur les freins, la tempé moteur …etc en plus). :cry:
Old 07-21-2015, 06:01 AM
Joe [FRA]
Joe [FRA]'s Avatar
Porsche GT3 Nürburgring - YouTube
Well, how to say... 2 words : awesome and fast
What are "your" specs (I mean how many Ring laps have you done ?) and the car specs ?
Will review your video again and again
Old 07-21-2015, 06:18 AM
Raven 666
Raven 666's Avatar
Great Vid ,I enjoyed that ..............
Old 07-21-2015, 10:38 AM
997rs4.0
997rs4.0's Avatar
Default A lap at the Nurburgring with a 6T3
Originally Posted by Joe [FRA
]Yes he did enjoy
In short,
He dislikes :
He loves :
Thanks for sharing! Always enjoy watching movies from the ring.
Just a little note on his comment on LSD issues when going of throttle in corners. IMO this is just a typical 911 syndrome and no LSD issue. Probably needs more time in 911s to appreciate the rear engine character.
Old 07-21-2015, 02:14 PM
4porsh
4porsh's Avatar
Impressive car and driving considering it's stock with PS2's on the RING!
Originally Posted by Joe [FRA]
Yes he did enjoy
In short,
He dislikes :
He loves :
Old 07-21-2015, 05:30 PM
JarmoL
JarmoL's Avatar
Thanks! My car has Manthey K400 kit with Manthey spec KW suspension and mk2 brakes. I am running Michelin PSC2 tyres.
I really don't know how many laps I have done there, around 200 is my guess.
Old 07-22-2015, 11:18 AM
keep it lit
keep it lit's Avatar
Hey Jarmo
tidy lap right there mate !
suspension looks good
i'm down at the 'ring in September for DN13 in the 3.9 mk1...
soon loon
Ade
Old 07-23-2015, 01:11 AM
vilfredo
vilfredo's Avatar
Joe,
I had an Opel Speedster for 10 years and switched to a 996 GT3 last year. Interesting to see that there are other people like me.
I will agree to the seating position being not ideal in the 996. My knees also get in contact with the wheel, and this is because of 1) wheel diameter being too big and 2) one cannot pull it wide enough. However, I do thing that the gear ratios are good for German roads - If you want to drive 300+ km/h (which I do occasionally), they're great.
Will watch your vids. Fortunately, I live unfar the Ring (hovever, I only go therr 2-4 times a year).
Marcus
Old 07-23-2015, 01:30 AM
vilfredo
vilfredo's Avatar
Interesting how you pass the Ferrari 430 and other cars before Schwedenkreuz. This is a tricky part of the track and much more difficult that it looks. I would not drive that far on the left side as I have seen too many heavy accidents there.
Re your friend: knowing the track is key here. Much more than on other tracks (71 turnes are difficult to memorize). No wonder that he masters this that well if he takes part in VLN. He would have been fast with almost any car, no matter whether 911 or even front wheel drive (Megabe RS). Will watch it again ;-)
Quick Reply: A lap at the Nurburgring with a 6T3
