Oil change gt3 996
Oil change gt3 996
Tomorrow I will be doing the oil change
From notes I found
Do I need to remove the fuse to the pump after I finished the oil and filter change so that I can turn the car over on the starter until I see oil pressure on the gauge?
Once I see the pressure, refit the fuse & warm the engine to do a final level check
Do I need a physical oil stick check or just the dashboard ?
From notes I found
You are making this more complicated than it has to be.
Jack it up, crawl underneath, drain, refit the plug, fill it up, and start it.
Also do the oil filter if you bought one.
In my experience, you need to pull the fuel pump fuse before draining oil. Then crank the motor until there is no fuel left in the system- you'll know as the car won't try to start.
Then proceed with the normal oil change procedure. Refill, crank until you see pressure on the gauge. Reinstall fuse.
And I believe it's fuse C4.
From notes I found
From notes I found
Besides the starter only spins the engine to maybe 75 RPMs and this is not enough to really develop any oil pressure. What this does is just spin the engine at too low an RPM that the residual oil doesn't form the desired hydrodynamic bearing (oil film) that requires speed along with pressure to develop. The bearing surfaces lose any residual oil they have. Then you install the fuse and crank the engine some more and it fires and the RPMs zoom to nearly 2K and all on bearings with less residual oil than they would otherwise have. Not what I would want to subject my engine too.
My 2002 Boxster with 288K miles has had an oil/filter change every 5K miles and the engine is just fine and I never have pulled the fuel pump fuse to crank the engine to build oil pressure. My 03 Turbo with 132K miles same thing. And both engines have experienced more starts than I can count and they are fine. And the same can be said for the millions of other engines around. This pulling the fuse and cranking the engine to build oil pressure is just silly, worse than silly for I believe it puts the very bearings that one thinks he is helping in some way really at risk of being inadequately lubricated upon actual engine start.
As for the oil change proper, you should warm up the engine to a minimum of 80C. This is the temperature at which - at least this is the case with my 996 Turbo engine -- I can check the oil level using the oil e-level system.
Then drain the oil. I do not know what the drain interval is for the 996 GT3 engine but of the 996 Turbo it is 20 minutes. (Porsche calls this "drip time".)
Then button everything up and add the specified amount of oil. This is where it gets tricky. The actual amount of oil to add to the engine to arrive at the proper oil level may not be the same amount as given in the owners manual. Engine oil volumes change over time -- as changes are made to the shape/volume of the oil tank or sump, etc. -- and Porsche doesn't bother to update the owners manual. The actual oil volume is tied to the car's VIN and the dealer parts department (or one of the techs) should be able to call this up for you.
In the case of my Turbo the factory specifies 7.8l of oil be used. So, you dump in 7.8l of oil (or whatever the amount is for your car) and dump this oil in slowly (as per the factory manual oil change instructions) and then start the engine and let it idle until you can check the oil level and confirm the reading is correct.
For my car the level reading should be at the max line, not below it and certainly not above it.
This is the way you ensure the engine has the proper amount of oil in it and the oil e-level system reading agrees with this.
Since my Turbo doesn't have a dip stick this is the only way I have of knowing how much oil the engine has, by carefully counting (and counting twice) the number of empty quart oil bottles I have.
At the dealer the techs have the benefit of an oil dispensing gun that reads out in 0.01l the quantity of oil dispensed.
brontosaurus (04-01-2021)
Also, there are two drain plugs. One on the engine sump and another on the oil reserve tank that is slightly forward and toward the passenger side of the car.
You will need about 10 quarts of oil.
You also need to get new crush rings for the oil drain plugs when you buy the filter.
Oh, have a roll of paper towels handy.
The best way to determine the correct change interval is to have the oil tested.
Just make sure you are testing the old oil and not the new oil...
I do the fuse trick:
1. When I replace oil (after car has been sitting all winter)
2. After its been sitting for a week or so without being driven
Personally I don't agree with the engine not reaching oil pressure with starter, the gauge recognizes pressure same as in idle. ( ~ 2 ) When you start the car, pressure is higher but its better than nothing.
The main reason I do it is my engine sounds completly different if I don't do it.Some check valve or something allowing oil to drain after sitting for a long time, but if I do the fuse prime it starts same as a warm start. I suggest you try both ways and listen to the engine at startup.. Im curious if you notice a difference.
I also read on these engines its better to fill some oil through oil filter tube.. You can see Kevin's post, he had these engines apart and I believe he stated there was no oil in crank case after emptying and filling majority of oil to sump tank.. Its been a while since I read that so you can try to re-read.
Here's a video:
View My Video
Based on the oil pressure behavior while cranking it would appear to me the oil pressure would take some time, if ever, to really climb. In the meantime the plain bearings are using up their budget of residual oil.
Oh, note the momentary drop in oil pressure after the oil pressure has peaked? That's from the VarioCam Plus switchover to low lift.
997 MAF when using 997 MAF housing?
deleted
