Shifter & Cables Combo Sale!!!
Basic Sponsor
Shifter & Performance Shifter Cables!!!
Now Available: Numeric Racing’s Shifter & Performance Shifter Cables!!!
Improves shift timing and accuracy!
Used by race teams worldwide!
PERFORMANCE SHIFTER
• ADJUSTABLE SHIFT LEVER
• PRECISION BALL BEARING
• 40% THROW REDUCTION
• ADJUSTABLE CABLE BLOCKS
• AEROSPACE GRADE ALUMINUM
• ENHANCES SHIFT TIMING
• COMPLETE DIRECT REPLACEMENT
• NO MODIFICATION NECESSARY
• LIFETIME WARRANTY
PERFORMANCE SHIFTER CABLES
• INCREASED CABLE DIAMETER TO ELIMINATE BREAKING
• STAINLESS STEEL MOUNTING CONNECTORS
• INCREASED STRENGTH & DURABILITY
• ENHANCED SHIFT CONNECTION
• PRECISE ENGAGEMENT
• ALUMINUM ROD ENDS
• ABSOLUTELY NO PLAY
• LIFETIME WARRANTY
PERFORMANCE SHIFTER
• LIFETIME WARRANTY
• ALUMINUM ROD ENDS
• LIFETIME WARRANTY
Basic Sponsor
offtopic, but i purchased your 986 shifter cables to match with a 997.2 rs shifter base with a 7in shifter riser in my 2004 boxster S.
the gears are always coming out. i put the car in gear, depress slowly and it comes out of gear by itself.
i had to reroute 1 cable Under my intake manifold cause it was too short, and the other one is still on top.
do you know what could be my problem?
thanks
thanks
Basic Sponsor
thanks
thanks
