996 GT2/GT3 Forum 1999-2005
996 (2004) Xenon headlight wiring diagram
Old 06-20-2011, 11:53 AM
MJP911
MJP911's Avatar
Default 996 (2004) Xenon headlight wiring diagram
Does anyone know where I can get a wiring diagram for the Xenon headlights on a 2004 996 (GT3). The PO put in some sort of aftermarket lights and I'd like to reverse the process.
Old 06-20-2011, 01:08 PM
911SLOW
Admin
911SLOW's Avatar
Marc I do have it and will post it here later.
Old 06-20-2011, 02:16 PM
MJP911
MJP911's Avatar
That would be fantastic - thanks!
Old 06-20-2011, 05:46 PM
911SLOW
Admin
911SLOW's Avatar
Let me know if this works for you.
Otherwise I will have to re-size it somehow.
(It's the wiring diagram for 2004 GT3/996 for US and Canada.)
Old 06-20-2011, 07:01 PM
996FLT6
996FLT6's Avatar
Looking at that diagram- sure looks heavy : ). Mike
Old 06-20-2011, 07:36 PM
MJP911
MJP911's Avatar
Unfortunately I cna't read all the labels in the diagrams - if its not too much trouble to send larger or PDF, that would be great - direct email might work better - I'll PM my email address.
Thanks!!!
Marc
Old 06-20-2011, 07:38 PM
911SLOW
Admin
911SLOW's Avatar
Marc I have your email already.
The problem is that this documents is in A3+ size and not in PDF format, hence I can't figure out a way to resize it..
Let me think about it and I 'll let you know..
Old 06-20-2011, 08:45 PM
plima
plima's Avatar
I have this drawing in pdf; I tried posting it but it is bigger than allowed, and when I reduce it to the allowed size, it isn't readable. PM me with your email and I'll send it.
Paul
Old 06-20-2011, 09:12 PM
MJP911
MJP911's Avatar
Paul
PM sent
Old 06-20-2011, 11:47 PM
MJP911
MJP911's Avatar
Got the pdf from plima - Thanks Paul!!!
Old 07-10-2012, 07:28 AM
jaguarx
3rd Gear
jaguarx's Avatar
DO YOU HAVE THE WIRING DIAGRAM FOR A 2003 PORSCHE TARGA (IN PDF FORMAT).
I HAVE PROBLEMS WITH THE LITHONIC HEADLIGHTS. LOW AND HIGH BEAMS DO NOT WORK WHEN INSTALLED. NEVERTHELESS I HAVE BEEN AVAIBLE THE ENERGIZE THE LOW BEAM WITH THE HEADLIGHT ASSEMBLY OFF THE CAR. I HAVE CHECKED THE VOLTAGE UP TO THE 12 PIN FEMALE CONNECTOR AT THE CAR BODY.
Quick Reply: 996 (2004) Xenon headlight wiring diagram
