996 GT2/GT3 Forum 1999-2005
squeak from front left suspension
Old 09-05-2005, 12:50 PM
Jerseybean
GT3 Track Junkie
Jerseybean's Avatar
Default squeak from front left suspension
I have a team of mice living in my front suspension - squeak squeak sqeak. Anyone have any thoughts as to what causing it?
Old 09-05-2005, 04:35 PM
Jim H.
Jim H.'s Avatar
Maybe they're hungry and just want some food? I'm not sure why else mice would squeak...
Old 09-05-2005, 04:43 PM
Z06
Z06's Avatar
Brake pads...on or off the could squeak
Old 09-05-2005, 05:01 PM
Jerseybean
GT3 Track Junkie
Jerseybean's Avatar
No it's not break pads, it's coming from the suspension itself especially when I hit a bad piece of road.
Old 11-29-2014, 05:22 PM
george996
george996's Avatar
i seem to have the same issue and was wondering if you ever figured it out.
Old 11-29-2014, 08:46 PM
Marv
Marv's Avatar
Probably the swaybar bushings are getting dirty.
Old 11-30-2014, 12:58 PM
IanM
IanM's Avatar
I get squeaks as well, for me its from the Tarret inner LCA monoballs. Did all my bushings last Spring. They're starting to wear in and get happy now, and the squeaks are starting to go away.
Old 11-30-2014, 08:11 PM
george996
george996's Avatar
against my better judgement i put a drop of oil on the swaybar bushing and no luck. all the rubber suspension bushings look good.
the sound is more like a chirp when going slow sharp bumps. no chirping when coming out of the driveway or swerving left to right. i can duplicate the chirp somewhat by jabbing the brakes. i am wondering if it the shock/strut.
Old 11-30-2014, 08:57 PM
lax01
lax01's Avatar
Sway bar drop links...just replaced mine and the noise went away. Slow, garage-speed bumps and ramps would cause a metallic squeaking noise from the front suspension. One of the ball joints is probably bad and making noise...
Old 12-01-2014, 04:44 PM
Gofishracing
Gofishracing's Avatar
or upper shock mount perhaps.
Old 12-08-2014, 03:39 PM
LuisGT3
LuisGT3's Avatar
Depending on how low you have your suspension set, it could be as simple as sway bars rubbing against the plastic cover. I had the same issue and just had to trim back the plastic a bit. No more mice.
Old 12-09-2014, 01:47 AM
george996
george996's Avatar
which plastic are talking about, the brake cooling ducts on the control arm? i don't there is an interference there but will double check.
Old 12-09-2014, 01:59 AM
george996
george996's Avatar
i am hearing more of a chirp similar to stopping on a painted line at a stop sign. i will try disconnection the sway bar for a test. thanks.
Old 12-16-2014, 07:39 PM
LuisGT3
LuisGT3's Avatar
I installed GT2 Club Sport cooling ducts and it was rubbing since then. I trimmed back a little bit of the plastic and that noise went away.
Old 09-28-2016, 01:09 PM
cgfen
cgfen's Avatar
This and the upper shock mount described below are the likely suspects.
George, did you ever try this?
Quick Reply: squeak from front left suspension
