Impulse purchase now being inspected and serviced at OPC
#46
I tried that today and didn't get any slipping. Hard to tell if pedal pressure is high unless I go joy riding in a few other cars. I see quite a few new owners take the route of immediate clutch and IMS fix as preventative action so maybe that'a just recommended where the background is unknown. I'm booked in for next Monday but still choosing from the menu items. What price peace of mind eh?
#47
My C2 Cab's clutch pulled perfectly when I bought it at 93k, but lack of service history and clean looking tranny bolts led my mechanic and I to the conclusion that the car was on it's original clutch. That, plus variocam chain rattle that would also occur at warm start led to decision for engine-out, full alpahbet soup of parts engine-refresh.
When the clutch came out it showed wear well into the rivets on the pressure plate side, but still just enough meat on the flywheel side where there was not yet any scarring damage to the flywheel.
My point being... these clutch discs can work really well for a very long time berefore showing signs of needing replacement. In my case, we got in there just early enough to reuse the flywheel, which saved me roughly $1k in additional expense vs. had I waited a month or two.
#48
#49
Shameful Thread Killer
#50
AOS can be taken apart and new diaphrams put in. I haven't tried it myself yet, but I have my old AOS here and bought diaphrams for it for $14 and will probably give that shot at some point... And if you ever sell the car and tell someone in-the-know that you had IMSB swapped as preventative maintenance, the first question out of their mouth should be "had it already failed?" It really helps to show them the old bearing along with the receipt so they can see it was not failing.
If the engine is coming out to do all of this, consider having your mechanic work up a leakdown & compression test for you. And be sure to keep the print outs or photos of the results.
I sold my black cab w/99k miles on it via Bring a Trailer a few weeks ago for, quite frankly, $3-4k more than I expected to get for it... The buyer told me on the phone afterwards that he was sold on the presentation of the car and the lack of question marks the mechanical condition of the car posed. Me keeping the old IMSB and original leather seat covers and including them in the sale made a difference. He also mentioned the used oil analysis and leakdown test as confidence builders.
You may have no intention now of selling the car anytime soon, but having those data points and evidence thereof will give a buyer of a used, former super car considerable peace of mind and will either 1) make your car easier to sell; 2) sell for higher price, or both.
Start a 3-ring binder and hole punch and file all of that stuff into a book. It all makes a difference.
#51
Interesting point regarding slippage and the pull test ... I test drove my car -- prior to purchase -- with the bad clutch. It pulled well and I couldn't feel any slip even at wide open throttle. The only clue, of sorts, was fairly high effort. From this, the shop thought that the clutch needed replacing. When the shop went to replace the clutch, the pressure plate was worn down to the rivets and had damaged the flywheel pretty badly. They had expected the worn clutch but were actually surprised that the flywheel was trashed.
#52
Also a good idea, I started a ring binder when I got my car, went from small to medium to extra large and its now thick with pages!
#53
All done now...
So I bit the bullet with my local Indy and had everything recommended to bring the car up to good drive able standard. I don't expect to have to go back until the next full service. I was doubting that I needed a clutch replacement but that has by far been the most noticeable from the driver's seat. Now the car is easy to drive, smooth, changes gear without any jerkiness etc. and I'm not getting a full leg workout on each journey. The IMS retrofit from LN was installed at the same time - not sure what I should be looking for on the original but it seems ok to me. Apparently I need to return this to LN in order to validate my warranty. Does anyone know if they send them back after?As all the discs and pads have been changed I'm going easy on the brakes at the moment but expect more bite to become evident, certainly it's less stressful driving knowing my stoppers are in perfect condition. Having AC is a bonus!
#54
Can't hurt to ask them to return it...
#55
(For future reference: This thread's title is the correct way to explain this scenario. Less effective ways of conveying information include gems like "HAVE MILSHAKE!")
#56
Remember folks Luke is in the English Rust Belt so brakes.suspension,exhaust work may be difficult.Encouraging him to get back into heavy diy car mechanics after a 30 year 'retirement' from it may be a little over enthusiastic? If it were an old MGB ,different story.
#57
"Luke...Use the Force..." evrything else will take care of itself
#58
#59
For the sake of putting potential future buyers at ease over outgoing bearing condition, I would think documentation/proof of proper LN warranty would also be sufficient. In your case, I'd either shoot some pics of the bearing and mail it in as asked to complete your warranty registration, or forego the warranty and hold onto the bearing.
From my readings in this forum, I think the LN warranty is more to pacify the need for consumers to have a warranty and serves as much less of a safety net than the word implies. I had the EPS Eternal cylinder bearing installed in my black cab during my engine refresh project, so I am not 100% on this as I did not research the LN warranty at all, but doesn't the LN only cover the cost of the bearing in the unlikely event that it should be proven one of their bearings failed? If so, the bulk of cost associated with such failure would be for labor and the host of other internal parts anyway, so the eventual value of said warranty is really only a negligible amount compared to the big picture should that happen...
I think member Gnat has an LN bearing in his car and instead of sending his in to complete the warranty process, he chose to have his old IMSB plated in gold and now uses it as his avatar photo, paperweight, conversation piece and decor item... Clever, still getting some "mileage" out of his old bearing.
