996 Forum 1999-2005
Need assistance license plate lights out
Old 03-20-2017, 12:56 PM
TomR9964S
TomR9964S's Avatar
Default Need assistance license plate lights out
I am only 10 days into being a Porsche owner. I found my license plate lights are not working on a '04 996 4S. Thanks to a post on here I was quickly able to remove the housings and replace both bulbs that were burned out. They are still not working. I put the multimeter on there and there is no voltage at either light. The fuse list does not show license plate lights other than position A7 (Canada.) All other lights seem to be functioning.
Does anyone know if there is a separate fuse for the license plate light?
Another thing, I noticed in the maintenance records for last year:
1. Repair Damaged Wires found during service
2. Rodent Damage To Rear Lid Latch
3. Removed Rear Lid Latch Repaired Harness Damage Reinstalled
4. Adjusted Latch, Test Operation, Completed
So I am thinking since the license plate lights are the same area I could have wire damage to them also. It looks like this would require rear bumper removal (how hard is this?)
Any ideas/suggestions would be welcome.
Old 03-20-2017, 01:05 PM
DTMiller
DTMiller's Avatar
Rear bumper removal is easy. pelican website has a step by step here:.
techarticles/Porsche-996-997-Carrera/46-EXHAUST-Muffler_Replacement/46-EXHAUST-Muffler_Replacement.htm
If there was rodent damage elsewhere in the rear, good chance there is a wire problem. I'd definitely start there.
Old 03-20-2017, 01:21 PM
Ahsai
Ahsai's Avatar
Agree with DT. Check fuse A5 first though, which is for the license plate and the cluster. There's a connector inside the rear bumper. Maybe someone removed the bumper before and forgot to plug that in.
Old 03-20-2017, 01:33 PM
TomR9964S
TomR9964S's Avatar
Thank you for the link DT. I am not a mechanic by any means, but the bumper cover removal looks pretty straightforward. Only other concern is my vehicle has OEM backup sensors as well as an aftermarket backup camera. It seems like I could have a lot more wiring under the cover than just the license plate light harness depicted.
Old 03-20-2017, 01:41 PM
TomR9964S
TomR9964S's Avatar
Thank you Ahsai. I try that next. The bumper cover removal is a pretty scary thought on a recently purchased vehicle I worked so hard to obtain.
Old 03-20-2017, 03:17 PM
DTMiller
DTMiller's Avatar
Just take your time and keep the removed hardware straight and it isn't hard, I promise. You might need a second set of hands to put the bumper back on to aid in getting it lined up, but this ain't terribly more difficult than changing a wall switch plate
Any wires that are connected to the bumper will have a release that will pop apart with the right combo of pushing and pulling.
Old 03-20-2017, 04:43 PM
TomR9964S
TomR9964S's Avatar
Thanks for the encouragement DT. This sounds like a father & son project. My son already thinks he is just three years away from driving the 996.
Old 03-21-2017, 02:30 PM
Noz1974
Noz1974's Avatar
I had this and as well as the number plate lights the bong to tell you your lights are on stopped working also as it's on the same fuse, if you noticed this also is probably the fuse!
Old 03-21-2017, 03:34 PM
TomR9964S
TomR9964S's Avatar
Thanks, no everything else is normal and the fuse is good. Although, it was not a Porsche dealer I am going to offer them a chance to fix it. One of my friends pointed out since they gave it a "fresh state inspection" they may offer to fix it.
Old 03-21-2017, 04:48 PM
808Bill
808Bill's Avatar
You can do it!
Old 03-21-2017, 04:53 PM
Gulliver
Gulliver's Avatar
While I do understand and appreciate the principle of asking the dealership to correct the issue, for me I believe I'd rather look at it myself. It would seem to be legally their responsibility, yes -but who knows who would get the keys to "go have a look at this guy's tag lights and see if you see anything...." That to me, is more terrifying than dropping a bumper cover myself. Good luck, and enjoy your new car!
Old 03-21-2017, 05:49 PM
dan_189
dan_189's Avatar
I find personally with this car if you just take the challenge, take your time and think logically.
Also remember it's a car, I had quite a bit of hesitation and thinking the dealership should do all the work but really for some things I can take my time and be more careful and do a better job.
Removing the rear bar is really straight forward.
There are only a few bolts and it comes off. There is a good youtube video I followed when I removed mine, I'll see if I can find it.
Old 03-21-2017, 06:07 PM
TomR9964S
TomR9964S's Avatar
Thank you, Dan. I found the video and yes it looks pretty straightforward. The dealer called about a hour ago and agreed to fix it. I'll punt on this one just in case it gets more detailed and expensive than just fixing a wire.
I am sure with a 12 year old car I will have many more chances to get my hands dirty.
Thanks again,
Tom
Old 03-21-2017, 10:14 PM
dan_189
dan_189's Avatar
Anytime Tom, plenty of jobs to be done eventually as well as preventative maintenance!
When I remember back to when I bought my car I wouldn't have dreamed of attempting the jobs I've done!
Old 03-26-2017, 02:57 AM
TomR9964S
TomR9964S's Avatar
Well, the dealership fixed the car for me. Whomever was last to remove the rear bumper cover did not reconnect the wiring harness to the lights. All good now. Thanks for all the help and encouragement.
Quick Reply: Need assistance license plate lights out
