Low oil pressure after service - Page 2 - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 03-20-2017, 10:05 AM   #16
Imo000
Captain Obvious
Super User
Imo000's Avatar
Quote:
Originally Posted by Noz1974 View Post
Yes I just bought one for mine , no chance of collapsing the filter as it's the all I one metal canister filter you use with the spin on adapter and also the benefit of full filtration with no bypass!
That filter can collapse just as much as the cartridge one.
Imo000 is offline   Reply With Quote
Old 03-20-2017, 10:06 AM   #17
extanker
User
extanker's Avatar
Quote:
Originally Posted by Imo000 View Post
The car should go back to that shop and have them figure out what happened. People make mistakes all the time, how they come through after it is what makes a good shop from a bad one. There is also the chance they didn't make a mistake either and you have another problem.
this
extanker is online now   Reply With Quote
Old 03-20-2017, 10:19 AM   #18
Quadcammer
Super User
was this an experienced shop? Could they have pulled out the pressure bypass plug by mistake and reinstalled it incorrectly?
Quadcammer is offline   Reply With Quote
Old 03-20-2017, 03:36 PM   #19
Noz1974
User
Noz1974's Avatar
I was meaning on install as could be on this occasion the cartridge one can twist , closing the pleats and reducing oil flow , how does a metal cased filter collapse, I haven't heard of this?
Noz1974 is offline   Reply With Quote
Old 03-20-2017, 05:17 PM   #20
dan_189
User
Could they have accidentally tried to drain the oil via the pressure relief spring and the spring fell out and they didn't put it back in properly or at all?
I recall another member on here accidentally did that when attempting their first oil change.
dan_189 is offline   Reply With Quote
Old 03-20-2017, 08:50 PM   #21
Imo000
Captain Obvious
Super User
Imo000's Avatar
Twist during instal??? Is there a ducumented case for this?
Cut open a metal case filter and you'll understand. On the inside it looks like the cartridge filter. Filters usually collaps when they get clogged.
Old 03-20-2017, 10:20 PM   #22
JayG
JayG's Avatar
Huh???
Drain the oil via the pressure relief spring?
Lucy, splain?
JayG is offline   Reply With Quote
Old 03-20-2017, 10:39 PM   #23
dan_189
User
Quote:
Originally Posted by JayG View Post
Huh???
Lucy, splain?
I'm trying to find the thread, someone on here went to change their oil but instead of undoing the drain plug they un-did the bolt that holds in the relief spring. Obviously they couldn't drain the oil like that but rather they thought that was the drain plug.
Perhaps they made the same mistake and re-installed the spring incorrectly causing low pressure?
Old 03-20-2017, 11:44 PM   #24
Cosmo Kramer
Cosmo Kramer's Avatar
If a shop did this I would hope that whoever worked on the car gets fired and banished from working on cars forever! I could maybe see someone doing it diy with no mechanical knowledge, but not a shop worker / mechanic. The oil drain plug on a 996 is so blatantly obvious you can't miss it.
Cosmo Kramer is online now   Reply With Quote
Old 03-21-2017, 12:54 PM   #25
JayG
JayG's Avatar
Unless I am completely misunderstanding this, the relief spring is inside the oil filter cover and that has a sealed bottom.
Where is there a bolt?
Old 03-21-2017, 01:00 PM   #26
AWDGuy
User
maybe they are talking about the spring bolt on the oil pump??!?
AWDGuy is offline   Reply With Quote
Old 03-21-2017, 02:17 PM   #27
Noz1974
User
Noz1974's Avatar
The relief spring is behind a bolt on the bottom of the oil pump housing , if you look under the car it's near the engine mounting bracket and exhaust system , further forward in the middle of the sump is the drain plug for changing the oil then further forward still towards the right is the oil canister, which does have a bypass valve inside but it's inaccessible without removing the canister itself ! But I can see how you might get confused, I think the suggestion is that the oil relief spring bolt on the bottom of the oil pump may have been removed instead of the drain plug, behind this bolt is three parts, a spring with a plastic dowel inside it and a piston, if the spring had broken or is missing, will definitely cause problems as when proper oil pressure is reached the piston moves down as the spring compresses to send oil back to the sump, if the spring is broken the piston will move easier, hence low oil pressure
I think you need to check this assembly to see if everything is there and spring looks ok
Check what oil was used then either change it or drain it and check the filter also and the canister as the bypass valve at the bottom can fail also!
Have the oil pressure checked with a mechanical gauge as your pressure sensor might be faulty
Maybe remove the sumo and check the oil pick up is clear.
Be careful about driving it as at this stage it could be an easy fix to restore pressure but if the engine runs without enough pressure it could cause major damage like cams being starved of oil and there are no cam bearings in these engines, the cams run directly on surfaces machined into the cylinder head, if they get damaged the head is scrap and it's going to start costing a lot
Not trying to scare you just be very careful!
Old 03-21-2017, 02:29 PM   #28
joe-1972
User
joe-1972's Avatar
Here's the oil pump... look under your rear bumper... you'll see this on the back of the motor...
The relief spring is under the nut to the right of the picture... it faces down when the pump is mounted to the motor.
joe-1972 is offline   Reply With Quote
Old 03-21-2017, 08:36 PM   #29
Woodman71
User
Woodman71's Avatar
Well dang, that explains the bolt I scraped on the asphalt the other day when going out of a driveway.
Woodman71 is offline   Reply With Quote
Old Yesterday, 01:11 AM   #30
billyboy
User
billyboy's Avatar
This is what it looks while laying under the back bumper. It's an easy way to drain a little oil if you overfill BTW.
billyboy is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
  • Ask a Question
What's your question?
Send
