Brake Fluid Leak From Bell Housing - Does it cause damage?
So I was just doing the final step of installing my engine, bleeding the brakes/clutch (full story in this thread: )https://rennlist.com/forums/996-foru...ft-begins.html)
Shortly after pressurizing the system to 15PSI with the Motiv, I started to hear a leak. Brake fluid was leaking from where the bell housing mounts to the engine.
Obviously the slave cylinder failed in a spectacular fashion (knew I should have swapped that out before reinstalling).
Do I need to worry about where that fluid ended up? I'm guessing when these fail, this is how they fail, and the fluid ends up in the housing, but do I need to worry about my brand new pressure plate, clutch, flywheel? Would really prefer not to pull the tranny.
I wouldn't worry about it too much. When I re-installed my transmission the clutch cylinder wasn't properly seated and then exploded when I tested the pedal. It was a huge mess. I cleaned it up a bit when I disassembled everything, put it back together, no issues at all.
I feel for you man. I'm becoming way more proficient at pulling/installing the tranny then I ever wanted to be. Both I gushed two slave cylinders due to lack of fork, both went to back together and worked fine.
