Ever see this before?
Nice A-10 mug. My Pops flew those for few years.
Received 1,919 Likes
^^hahaha... Maybe I should have said, " What's your secret?" instead.
Looks like the rod bearing on number one was somehow oil starved and spun. The crank, rods, carrier, cylinders, chains, lifters... everything... is in remarkable shape.
After careful consideration by all of my trusted but not Porsche experts who have over 100 years of combined experience with rebuilding every type of combustion engine from aircraft to tractors, this POS is getting rebuilt with nothing more than new bearings.
Simple, she gave up years ago and left and I had the good sense to not replaced her But seriously, I never imagined these parts would end up on the table. They were great company for dinner last night!
Manually probe the hole in the case where the oil filter attaches, to check for more metal debris. Have the case & heads ultrasonicly cleaned to clear oil & coolant passages, otherwise you WILL have metal shavings circulating throughout the engine. After installing new thrust bearings & the crankshaft in it's carrier, check crankshaft endplay! That may be what liberated the thrust bearing on your last visit to redline city!
Captain Obvious
Super User
Super User
I think it's pretty simple. My theory is that the pick up screen got clogged with the cam tensioner pad material and that caused the oil starvation, that then caused the bearing to spin.
