996 Forum 1999-2005
Looking for a 996 project car - The journey begins
Old 02-11-2017, 12:41 AM
  #76
MiataR
MiataR's Avatar
Originally Posted by mrjonger
If you live where I think you live, you have no pity from me...small price to pay for paradise. =P
Maybe... I just heard of two more roads that got washed out in the storm.
I don't really remember, but I thought you could just pull out those rubber grommets and stick your finger through it?
I tried pulling on one, and it didn't come out very easily... so I took the old-skool route and just pulled out the debris.
I'm guessing you don't have the rear drains because of the sunroof delete.
You are correct.
Old 02-11-2017, 12:45 AM
  #77
MiataR
MiataR's Avatar
A bunch more parts arrived today, but I need to travel for about a week, so I dropped the car + parts off at my local indy to keep things moving forward.
Maintenance
Clean out front radiators (done)
Unclog drain holes (done)
Oil/brake/transmission fluid (pending)
Blackstone oil analysis (pending)
Parts Installed
Michelin PSS Tires
Parts received but not yet installed
GT3 Console Delete - needed to order a trim piece before I can relocate the HVAC controls
Tarett Monoball Camber Plates - Front
OEM Fuel tank valve
NGK Spark Plugs & coils
Belts
FVD Motorsport Oil Pan with Baffle
Magnetic oil drain plug
Air filter
Pollen Filter
Water Pump
Parts ordered
Wevo semi solid engine mounts
AC/HVAC control trim
Adjustable Endlinks - Front/Rear *new* (thanks Slakker!)
Stage 1.5
Coilovers - GT3 vs. Ohlins vs. KW V3?
Monoball Camber Plates - Rear
Stage 2
Clutch+Flywheel (Light weight?)
IMSB - dual row LN solution
RMS
Short shifter (997/GT3/other?)
Upgraded AOS
New rotors/Brake pads
Suspension bushing refresh (Powerflex?)
Old 02-11-2017, 02:02 AM
  #78
ocmacman
ocmacman's Avatar
Great job. I am just finishing my 997 project. I think 996s are really coming into their own now.
Old 02-14-2017, 04:11 AM
  #79
MiataR
MiataR's Avatar
While I've been traveling, the car as been in the very capable hands of Trackspec Autosports, and they were kind enough to send out pictures as progress was made.
In addition to an oil change and sending a sample of the current oil to Blackstone for analysis, the new FVD oil pan went in today.
Old 02-14-2017, 04:20 AM
  #80
MiataR
MiataR's Avatar
Also, I decided that a suitable starting point for a combination street/track car was a set of GT3 coilovers, so picked up a set with ~10k miles from a fellow Rennlister.
Old 02-17-2017, 02:08 AM
  #81
MiataR
MiataR's Avatar
Some updates:
Wevo engine mounts installed.
New serpentine belt:
New Air filter vs. old:
New coils and plugs vs. old:
Old 02-17-2017, 02:13 AM
  #82
MiataR
MiataR's Avatar
I've also decided to get the remaining maintenance items taken care of while the car is in the shop:
1. Upgraded dual row LN IMSB retrofit
2. EPS Clutch kit
3. New dual mass flywheel (decided against the LWFW)
4. New RMS
5. New AOS
6. New chain tensioners
Parts are on order...
Old 02-17-2017, 03:03 AM
  #83
rolex11
rolex11's Avatar
2. EPS Clutch kit
4. New RMS
5. New AOS
Looks like you got the updated 997 coils that come with longer bolts because of the thicker coil heads. You'll need to get some spacers for those bolts so you can reinstall your heat shields. The heat shields won't fit without them, they will hit the coils head.
This is assuming you have heat shields to begin with.
Old 02-19-2017, 01:55 AM
  #84
MiataR
MiataR's Avatar
Thanks for the tip. Will keep that in mind when we put everything back together.
Old 02-19-2017, 01:57 AM
  #85
MiataR
MiataR's Avatar
The transmission is down and the old clutch and FW are out. They were definitely due for replacement.
New parts should arrive early next week.
Old 02-19-2017, 02:02 AM
  #86
MiataR
MiataR's Avatar
Needed a set of sway bar mounts for the GT3 coilovers, so I ordered a set of these:
Old 02-19-2017, 02:08 AM
  #87
MiataR
MiataR's Avatar
A quick review on where things stand on the maintenance/mod list.
Maintenance
Oil/brake/transmission fluid (done)
Blackstone oil analysis (sample sent - pending report)
Alignment (pending new suspension install)
Parts Installed
Michelin PSS Tires
Belts
Air filter
Pollen Filter
Water Pump
GT3 Console Delete
OEM Fuel tank valve
GT3 coilovers
Parts ordered
Clutch+Flywheel
New RMS
New AOS
Tarett sway bar mounts
"Stage 2" List
GT3 swayers (looking to source a set - please PM me if you have a lead)
Fister (or equivalent) exhaust mod
Old 02-19-2017, 02:13 AM
  #88
Slakker
Slakker's Avatar
PM sent. I have a new set of these I don't need and will give a good discount on.
Old 02-19-2017, 02:15 AM
  #89
MiataR
MiataR's Avatar
Bah... should have asked first.
It's too late, they are already on route.
Don't suppose you have a set of GT3 (or equivalent) sway bars?
Old 02-19-2017, 02:24 AM
  #90
Slakker
Slakker's Avatar
I have a front GT3 bar.
Quick Reply: Looking for a 996 project car - The journey begins
