Looking for a 996 project car - The journey begins
#32
Here's a glimpse into the next set of expenses:
Stage 1.5:
Coilovers - GT3 vs. Ohlins vs. KW V3?
Tarett Endlinks - Front/Rear
Monoball Camber Plates - Rear
Stage 2:
Clutch+Flywheel (Light weight?)
IMSB - dual row LN solution
RMS
Short shifter (997/GT3/other?)
Upgraded AOS
Engine mounts
New rotors/Brake pads
Suspension bushing refresh (Powerflex?)
#33
Very nice. I Like your upgrade list, very methodical and purposeful.
How is the condition of the tires? I would put on your favorite set if those tires are old even if they appear to have great tread.
A fresh set of tires and alignment often does wonders to a new to you car. But I could see how you may want to way for all the suspension components to be put in first.
#35
Thanks.
That was the first mod. I now have a fresh set of Michelin PSS on the car... love them
Yes, that's the plan. Need to research appropriate alignment settings to use for a dual street/track car.
#36
I opted for 0 toe, -1 camber front, -1.5 camber rear .08 caster (but I really don't believe caster makes a huge difference in the car as the wheel base is short enough)
For more aggressive track use, I would for sure opt for much more negative camber at the expense of tire wear. I am definitely no expert, but I did go back and forth with 3 different alignments til I felt it was 'just right' Right for me is if I accelerate out of a corner, and I can feel the rear wheel bite the ground with neutral tendencies, and good rear tire feedback. I know many prefer the exaggerated oversteer feel, but I don't think i'm quite ready for that yet.
#37
Ah, look what arrived today.
Thank you Mr. Vandersmith (the Porsche tape was a nice touch).
Excellent, looks like I now have a weekend project...
#39
Rear: 265/35/18
I briefly considered 285 for the rear and then decided to keep the original size for now.
#41
One other surprise today:
So, the remote lock/unlock function on the primary key fob I've been using hasn't been working (the LED doesn't even light), so I've been manually unlocking the doors on the car.
Reading through the various threads on key fob issues and likely problems with the PCB, I feared the worst and ordered a new key+fob from the local Porsche dealership. But then, on a whim I ducked into the local Target and bought a replacement battery. ~$3 later I now have a working Fob.
I'm still going to get the extra one from the dealership and then keep this a one as a spare.
#42
LOL, I just realized my "sun roof" is a hard top and not glass... I can not see out of it. I can only open it up.
Are all the Porsche sunroofs that way? hard top essentially, not glass to see through??
#44
Mines like that too, from what I've seen all the 996s are like that.
