FVD Sport Cat 200 Cell X-Design Review
No idea what lift it is. It is the shop where I bought the Cargraphic mufflers.i did not further pay much attention to it. Why do you ask? In the photo there are no lift parts visible I think. The beam in the back on the right side is from the building and is way more in the back.
For the headers I decided to do some hit and miss via e-bay. I ordered a set and then evaluated build quality and welding in order to decide to keep or return. The 4th set I ordered looked very well made and solid.
I then decided to also order the cats there. Here is the link. The fit on the headers was spot on without any readjusting. It has a larger bore diameter and came with an adapter to taper down to the OEM diameter \of the mufflers. This was a little bit tricky as they needed some more of the exhaust kit as usual to make it airtight. Optically with the additional adapter it looks also less bling. They also provide a x-pipe with normal diameter. As well as normal cats.
I have FVD 100 cell x-pipe cats.... amazing product! they are like increasing the volume on your car.... if you had drone it will magnify it... the source of drone is a bad exhaust - I have PSE so no issues at all - at any rpm -
FVD makes a solid product - highly recommend them.
