996 Forum 1999-2005
Are there ANY group IV PAO oils I can buy in the US?
Old 07-30-2016, 01:37 PM
docmirror
Shameful Thread Killer
docmirror's Avatar
Originally Posted by KNS
Interesting question regarding the Euro Synthetic. I would think the settlement has more to do with our litigious society in the US...
Anything litigation-wise in the US has to do with money. Buckets, and buckets of money. Frex - I give you, the VW cheating settlement. Although the EU is very green politically the owners of the same cars in EU aren't going to get squadoosh. The syn oil lawsuit was something between the big oil giants where one of them was caught mixing in the paraffin/mineral in their branded synthetic. Lots of makers started using some version of "Syn-blahblah" in their names, but the oil was a hydrocracked mineral. The biggest pocket litigator won I presume, and since that idiocy, anything goes. Only in the US does synthetic actually mean naturally occuring but purified/hydrolyzed...
Old 07-30-2016, 01:44 PM
Macster
Macster's Avatar
Originally Posted by docmirror
While web site touts it is a "100% synthetic oil" it relies up "sub-micronoic colloidal particles" of "graphite, PTFE and MoS2" to deliver its claimed superior performance.
I would prefer an oil that delivers superior performance because of its oil not from "colloidal particles of graphit, PTFE, and MoS2".
Old 07-30-2016, 01:53 PM
Macster
Macster's Avatar
There's a number of group III and group IV blends. This trend started after the lawsuit in the US allowed mfg to claim hydrocracked mineral oil to be called 'synthetic'. I'm guess here, but since the cost of the hydrocracked mineral oil base is about 30-40% the mfg cost of the ester/PAO cost, that the blends are likely 80:20, or 90:10, or 99:1 mineral:PAO. Of course, no mfg will come out and tell you what the blend ratio is as it's proprietary, but the fact is, they are in business to make money, and PAO cost more to put in the bottle. Will some vendors trade on their name and reputation? Of course they will.
So I guess I would be ok with a blended oil, but only if I was able to know the ratio of mineral to PAO, and so far no one is talking about that. I remember well the early days of Mobil-1 and their scandal with the early true synthetic(man made, esters) and some of the issues it caused. Mainly in the auto world, it was swelling or leakage past seals and gaskets. So, it's pretty easy to tell when a 'synthetic' is actually a class III because it doesn't leak where a seal may be partially compromised.
Which brings up an interesting point, and here I will use the dreaded IMSB, so one may pass this by if they don't want to hear about it. I'm wondering -- because the word 'synthetic' in AU, and Europe must mean group IV oil and cannot mean group III, has there been any studies done on the IMSB failure rates between US and other countries where there may be much higher use of actual PAO ester type oils? All I ever heard about was the settlement with US owners but if there's a correlation with higher failure rates in the US, that might be interesting.
My info is PAO oils are seal unfriendly. Seals can shrink and leak. Additives, a bit of ester oil, is added to counter this. 'course, with infrequently used cars the seals still can experience shrinkage. The ester is of no value if it remains in the oil sump.
For a full synthetic oil one in which there is no petroleum base stock used -- even though this base stick is highly refined to the point is it more synthetic than natural -- I think you need to seek out a Group V oil. These will be ester based.
A problem is with ester based oils is with all this ester the oil can cause seals to swell. This can result in increased seal friction which could lead to premature seal failure and leaks down the road. Also, my understanding is once an ester based oil has been used in an engine it is not recommended one switch away from an ester based oil back to a PAO oil.
But if you want a fully synthetic oil (and likely an expensive oil) a Group V oil it is.
Old 07-30-2016, 03:09 PM
docmirror
docmirror's Avatar
Yeah, I'm on the fence as to whether this is some mineral based snake oil or not. They sell a product without the colloidal stuff added, but the more I read, I don't see anywhere that says it's a PAO or ester based product. The verbiage is very cagy and in a lot of places it says what it's not, but hard to find out what it actually is. One statement buried in there says 'non-petroleum based' lubricant. Lots of words that don't mean anything until I can see the MSDS, and I can't find that either yet.
Old 07-30-2016, 04:05 PM
MoeMonney
MoeMonney's Avatar
So whats the end goal? im trying to understand, to find a group 4 oil that is fully synthetic so you can use it in your 911? Are Motul 8100 excess and joe gibbs DT40 not good enough for your requirements?
Old 07-30-2016, 05:08 PM
docmirror
docmirror's Avatar
It's in the first post. Yes, I want a 100% actual synthetic(non-petro) oil for use in my 911. As for the other oils not being good enough, I guess I want the option to decide if I would use a true synthetic, or some blended mostly petro oil. Right now, so far, I don't have the option to use a PAO.
I've got a reply from a blender that has gobs of BS about phase separation of various additives from the PAO. So far, that hasn't really been a problem for the turbine world where the PAO oil is almost universal, including additives(however, the package is quite different). Anyway, they want to sell their specific additive blend because they think they have the best goo in the world. Maybe so, but it's not what I'm looking for. Plus, the additive package for PAO base oils is typically much smaller than for petro base oils(higher VI, means fewer viscosity modifiers, etc). I'm thinking that with the past 25 years of development, most of the big houses have the phase separation issue worked out. Also, I'm also fairly certain that the seals issue has been resolved or we would be hearing about all the leaky engines in EU/AU where PAO engine oil is common. We don't hear that, and all those OWT from the 70s aren't an issue anymore. It's like the problem with old carbs and Ethanol fuel. Sure, Ethanol is very bad for legacy fuel systems, but by 1998, things were pretty much wrapped up on that problem.
Old 07-30-2016, 09:04 PM
Ahsai
Ahsai's Avatar
Yup on sale right now, $7/L shipped to the door.
Originally Posted by KoB
FWIW, I buy my Motul from Amazon ... their price on the 4-pack of 5-liter jugs is pretty good if you have Amazon Prime.
Old 07-30-2016, 09:55 PM
docmirror
docmirror's Avatar
Castrol syntec Edge is pretty much the same chemistry as Motul 8100 for ~$4.70/L in the 5 quart jug.
Old 08-01-2016, 12:07 PM
Gulliver
Gulliver's Avatar
Dang. And to think, for 125k miles I've just been using Mobil 1, like Porsche told me to.
Quick Reply: Are there ANY group IV PAO oils I can buy in the US?
