996 Forum 1999-2005
Help - Engine cover / alternator bracket
Old 07-18-2016, 09:40 PM
Cru_Jones
5th Gear
Cru_Jones's Avatar
Default Help - Engine cover / alternator bracket
Greetings.
I'm usually more of a lurker, but couldn't find a lot of information on replacing this part and was hoping somebody here could share some knowledge.
A little background: I have a 2002 C4S, with (now) 70k miles. I've had it for about 5 years.
I was replacing a noisy idler pulley and discovered this cracked cover/front mounting point for the alternator:
The crack was barely noticeable, but as I pulled off the idler pulley (upper bearing - so the mounting bolt supports the other side of the alternator) I could see that it's completely sheared off. With the new bearing and drive belt back in place, there seems to be enough tension to hold the two pieces in place, but this clearly needs replacement.
I was able to quickly track down the part number(s), listed in PET as simply a "lid," 996 101 021 51 which was superseded to 996 101 021 52, both of which were superseded to 997 101 021 00. I opted for a good used 997 part rather than pay the $350 (cheapest I could find) for a new piece. I also made sure to get a new gasket.
As a side note, comparing the 996 part (left) to the 997 version (right), it's clear they beefed up the supporting material around the upper bolt where the alternator mounts (the area that failed on my car).
Here are my questions:.
1. Has anybody else here experienced this failure, or replaced this part? I'd appreciate the sharing of any wisdom learned in the process.
2. I realize there's coolant running behind the lid, but as this is at the top of the motor, can I get away just with partially draining the coolant? Would setting the car at an incline (nose pointing down) before removing the lid help minimize the coolant in that area? (Without opening up a can of worms) I'd like to avoid having to vacuum purge air from the cooling system and am thinking that if I'm only partially refilling I can use the purge valve.
3. From what I understand that hose connector can be finicky and is prone to breaking. Any suggestions or advice for working with it?
4. Does anybody know what the correct torque settings should be for the six mounting bolts on the lid, or the alternator mounting bolt?
Any other thoughts/considerations/insults for not regularly contributing here?
Thanks for any help,
Nate
Old 07-18-2016, 10:22 PM
Ahsai
Ahsai's Avatar
1. One post I remember here https://rennlist.com/forums/996-foru...install-2.html
2. You should loose at most the whole reservoir worth of coolant. You won't need the purge tool if that's indeed the case.
3. Some has converted that to a brass barb. I'll just get a new OE 99610622652. There's also a stainless steel version for $40 https://www.carpartsdiscount.com/coo...ml?3593=525804
4. 7.5ftlb for the small bolts and 17ftlb for the big alternator anchor bolt
Now my turn What's the p/n of your used 997 cover? Have you fitted it and made sure all the holes line up and the alternator anchor hole is at the same location as before?
Old 07-19-2016, 12:18 PM
Cru_Jones
5th Gear
Cru_Jones's Avatar
Thanks Ahsai, you've pretty much answered all of my questions! I did read through the post that you linked.
There does seem to be some confusion with the part number. I'm traveling this week, so can't verify 100% - and I haven't taken the old part off yet to compare - that these are identical in alignment. I'm sure hoping that they are. I will definitely let you know what I see when I get in there.
I found that the 997 part (997 101 021 00) is stamped on the inside with a different number- 997 101 215 00. And the 996 part number (at least the one that Parts Heaven had on hand) was stamped 996 101 2115 9R (instead of 996 101 021 51 or 52). If you look at the picture that you posted in your link, which looks the same as this one on the part page for 997 101 021 00 at Auto Atlanta - it's stamped 997 101 215 00. I'm sure there's some logic behind all of this. I believe they're the same part.
Old 07-30-2016, 12:49 PM
Cru_Jones
5th Gear
Cru_Jones's Avatar
Just closing the loop and updating this thread.
I replaced the cover with the 997 part that I received. Fortunately, my part came with all both hoses, to and from the t-connector. Interestingly, the connector from the t-connector is different on the 997 part vs the 996 one, and uses a smaller hose and quick connect type of fitting on the end. I didn't mess with that, and just used my existing hose and the new t-connector.
Before I took the old cover off, I syphoned out all of the coolant from the expansion tank to a clean bucket using a new (clean) hose. When i removed the cover, I lost (at most) about a quart of coolant. The new part is an exact fit and I had zero issues installing it. Some pictures below showing the two parts side by side, and the end result. It may look like one is slightly larger than the other - that's just the foreshortening effect of the iPhone - they are the same.
Unfortunately, I did hit a snag in removing the lower idle pulley when the mounting bolt sheared off. Fortunately, I was able to get the broken off portion out of the engine case using needle nose pliers (Whew!!) A quick call to Suncoast and a couple days later, and I was back in business. One thing I noted is that the mounting bolts for the idler pulleys (I opted to replaced the upper as well), have superseded to newer numbers. The lower bolt has changed slightly and is threaded the length of the bolt (my original had a smooth shank and then threads). The upper bolt now has a torx head in place of the hex.
Part numbers I used were: 900-378-159-01 (lower), 900-385-092-01 (upper).
Old 07-30-2016, 12:59 PM
wyovino
wyovino's Avatar
Nice job and great follow-up! I'm sure this will help someone down the road. (No pun intended)
cds72911 (10-12-2019)
Old 07-30-2016, 01:10 PM
Ahsai
Ahsai's Avatar
+1 Good job and thanks for confirming the 997 part works. The used ones for 996 are on short supply and a new one is just crazy expensive.
Old 08-01-2016, 12:24 AM
russellclaude
russellclaude's Avatar
Default Thanks for this thread!
Although I have not fixed my busted mount, yet, I have the same problem on my 997, and I haven't had much luck anywhere else on the web getting info on this issue. I am considering fashioning a secondary brace so as to leave the coolant part in place. Just need something to secure the alternator. Its an expensive part to replace!
I have no idea how it broke. Just started rattling one day last week, and haven't done any work in the engine.
Thanks again. -russ
Old 08-01-2016, 12:37 AM
russellclaude
I thought this thread was a couple years old or something - started last week! Crazy! That's when my issue started, too!
Old 08-01-2016, 12:42 AM
russellclaude
If I completely replace the mount, will I have to remove the accessory belt? Thanks. -russ
Old 08-01-2016, 01:53 AM
Ahsai
Ahsai's Avatar
I would think that's the easiest (will create much more space) and also you don't want coolant to spill on the belt.
Old 08-01-2016, 04:28 AM
rayben
Cruisin'
rayben's Avatar
Nice job! Thanks for the follow-up!
Old 08-01-2016, 01:12 PM
Cru_Jones
5th Gear
Cru_Jones's Avatar
Russ-
Assuming that these areas on the 997 are the same or similar to the 996...
I think if you're willing to replace that cover, taking <5 minutes to remove the belt is a no brainer. I'd also suggest taking both the upper and lower idler pulleys off. On the 996, the bottom pulley is right in the way of one of the cover mounting bolts. I also removed the top one as that pulley's bolt serves as support for the right side of the alternator. It seems more logical to re-attach the alternator to the pulley bolt first before connecting it to the tab on the new cover (which apparently has some weakness).
For the cover itself, I'm not sure how you can brace it without taking it off first - and if you're going to go through the trouble to do that, I'd just replace it. I had also considered bracing or finding somebody that welds aluminum, but both of those options felt like inappropriate solutions for a car of this caliber.
If you're searching for a used part, look for both the number stamped on the cover (997 101 215 00) in addition to the actual part number that comes up in Porsche's catalog (997 101 021 00). I personally wouldn't put one of the 996 covers on your car, even though it would probably be a direct fit and more readily available.
Happy to share anything else I learned in the process if you have any questions.
Nate
Old 08-02-2016, 11:36 PM
russellclaude
Originally Posted by Cru_Jones
Russ-
Nate
Thanks. I have all parts ordered and a new belt on the way. Was driving in my neighborhood and my belt shredded. Guess I should not have been driving with the cracked alternator mount.
Everything is ready to install when parts arrive.
Even the beefier 997 mount is prone to busting.
Wish they made it more substantial.
Old 08-21-2016, 12:31 AM
russellclaude
Update here:
https://rennlist.com/forums/997-foru...-2006-c2s.html
I had my broken part welded back together, and its as strong as ever. Crazy its a $480 part. If you don't get that primary alternator mount/pulley bolt tightened properly you're gonna break these again and again. I have broken 2 in the last month!
Old 02-28-2017, 11:54 PM
Miller_arch
Miller_arch's Avatar
For whatever it's worth I did not experience the aluminum alternator bracket failing, but the plastic component that you will see in post #4. That plastic component was very weak...both of the posts that connect the tubes broke inside the hoses.
Quick Reply: Help - Engine cover / alternator bracket
