My new '99 C2 Coupe Track Car
#376
Desperate times call for....
#381
Originally Posted by sweet victory
Getting closer! Headed out for spring break then will pick it up when I get home next weekend. Can't wait to get back to work on it.
#382
Great progress- Good luck with the continued repair and getting it producing smiles again!
#384
Originally Posted by dgmark
A big plus to 996 track cars is that used body parts are cheep.
#386
This should be your new paint/wrap job:
#387
Hey there!! Most impressive build!! Have you considered the Electronic Water Pumps? Removes all heat soak issues and you just dial in the temp you want and it stays there - regardless of how hard you're pushing. Plus, the pump keeps circulating coolant after switching off - this is a very good thing! EWP's are being fitted to all the new generation BMW and Mercedes engines and have been used in drag racing for many years... I'm going to fit one shortly. Also can reward up to 10kw of power!
https://daviescraig.com.au/electric-water-pumps
#388
Thanks!
Interesting. Since cooling isn't an issue I probably won't go this direction anytime soon but it's good to know it's out there. And am very skeptical of manufacturer HP increase claims, especially on an M96.
But something I think that is definitely worth checking out is an electronic power steering pump. Unfortunately, nobody that I've been able to find makes a serpentine belt for PS delete, AC delete and underdrive pulley.
#389
I hear you on manufacturers claims - they're usually overstated... However, it would stand to reason that one less parasitic drive removed will introduce some power - how much is the question.
I'm interested in the heat-soak removal too. I know that after some spirited track days the engine is considerably hot and when turned off the water flow stops, so I think this must be an advantage in engine protection etc...
I'll go ahead with my install and report back!!
Take care...
Take care...
