Atlas TD6MR Lift Review
"meaning you will need to position the car very far back on the lift "
Careful !
This may be tipy ? The car is already weight biased to the rear and when the engine+trans is released that changes !
In such situations I use very tall underhoist stands under the arms of a 2-Post.
http://www.harborfreight.com/2-ton-c...and-60759.html
Careful !
Originally Posted by mcfisticuffs
how high is your ceiling? 8'?
Agree - I won't know if it's true for sure until I try it...and you won't know unless I post pictures . I couldn't find any visual evidence to confirm or deny, but it certainly appears that the rear cross member of the lift will not impose on dropping the engine/tranny - you just make sure the car is oriented safely toward the rear of the lift.
Im discovering that taking delivery of these is also a challenge.
basically I would need a forklift or a crane. Not to mention a 53 foot truck would have a hell of a time up my driveway then turning around.
hmmm
hmmm
Easy-
Present your challenge on Grage Journal.There are many threads that they will refer you to to solve the problem.
I collected,unloaded and installed a Mohawk alone. If I can do it.....you can too with some advice from GJ
Talk to the guys at Greg Smith also. But first make sure you are aware of all the new lift options out there.
For me the big issue was where do I buy a replacement seal kit ? Amazingly ,many Lift seller had no clue. I can buy every single part for my 1980 manufactured Mohawk from the factory.And they give excellent service over the phone. Try that with the chinese lifts !
That was fast !
Here is a write up on this Lift for others. There is also a comparison with Maxjax and others if you google GJ
http://www.garagejournal.com/forum/s...d.php?t=332754
That was fast !
I want a open center for dropping motor/trans
mid rise
FYI, 22" to the jack point gives a good 1-2" clearance to remove the engine assuming a 6" minimum jack height.
So you reversed the direction of the car to bypass the cross member on the lift. The lift hydraulics now become the tricky part to work around.
What type of lift table are you using in your picture? Any other gotchas to share?
Steve, I have this one.
http://www.harborfreight.com/500-lb-...art-60730.html
They have a 1000 lb capacity for $100 more.
Another thing I learned.. My lift came with two seats of lifting pads, high (for trucks and suv's) and low for cars. I lifted the car with low pads onto wood blocks so I could transfer to the higher pads. The higher pads allow clearance to remove underbody covers and easier access to front trans mounts.
Go for "Double Scissor" cart and you get 60"+.But way more expensive.
example "BCART-1000D-DC Double Scissor Lift Cart"
