PCM/NAV Codes not working
Hello,
I have a 2002 996 TT. I've been away and the battery went flat. After charging, the radio/nav asked for the PCM and NAV codes. It took the PCM code but won't take the NAV code. Any way to check if I have the wrong code? It keeps me locked out
Thanks.
Thanks.
i have a 2002 911 TT battery died no radio code in my car. I have called three dealers all gave me the same code but it does not work.
It is a becker pcm model 2582 serial #15009572 the other serial number Po8160005286/01
The code all three gave was 1796 no luck! Any thoughts?
