How much metal is too much?
I changed my oil today after about 10 months and 4000 miles. I'm flushing her with Driven BR30 for 500 miles and then will switch over to Driven DT40.
When I took a look at the old oil filter, there were some plastic bits and also a few ferrous pieces here and there. Most looked like a short, thin wire.
So the question is: how much ferrous metal is too much in for an oil change?
Do you also have a magnetic drain plug? If so, anything there? If not, I'd recommend one with the next oil change. I would not be too concerned with the filter contents. Keep the pictures above for comparison at the next oil change.
What you see is normal. I don't understand why you went to the BR oil, that is break in oil, has very high levels of zinc for breaking in new metals.
FYI, my filter looks the same, and I just changed the oil on my 2007 Audi S8 a few weeks back, cut the filter open on that car (has 70K miles) and found exactly the same. Never cut any of my Audi filters open before.....
