Rear window lower trim removal
Odd Posts
I appear to have rattle in trim between the rear deck and the rear window.
I would like to investigate. Does the trim piece just pull off, or is there a special way to remove it?
I think the panel you're referring to is welded into place (if its on the outside of the car). If its on the inside the rear panel/leather one just pulls out and is held in with tabs. There is only one part behind there and its the rear wiper motor. It might be loose? If its on the outside maybe check the brake light.
