996 Forum 1999-2005
readiness monitors
Old 11-11-2015, 12:41 PM
JayG
JayG's Avatar
Default readiness monitors
I had a CEL a week or so ago and got P300, P301 and P303 codes. They are misfire codes.
Cleared the codes and replaced the coil packs.
Still not 100% sure it was the coil packs and not an temporary injector issue.
No other codes present or cleared
In any case, I have 2 monitors that have not reset;
Catalyst and Evap system
I have driven the car a bit and even did an AX a few days ago.
How do I get the the monitors to reset and show ready?
Old 11-11-2015, 01:16 PM
Kalashnikov
Kalashnikov's Avatar
There is a specific sequence of things you need to do in order for all of the monitors to reset quickly. I followed this to a T because I kept getting the SAI valves codes and needed to pass the OBD test in AZ. I reset the codes with OBD reader and did this cycle on the way to the test place. Car passed.
Drive cycle sequence I got off the web for my car is:
Start engine, idle cold for approx. 2 min, 10 secs.
Accelerate to 20-30 MPH, Maintain steady speed for approx 3 min, 15 secs.
Accelerate to 40-60 MPH, Maintain steady speed for approx 15 mins.
Decelerate and come to a stop. Idle in gear* for approx 5 mins.
Ahsai
Ahsai's Avatar
Try this:
Cold engine idle for 2 minutes, then 10 miles local (with some traffic. Congestion ok) then ~10 miles highway as much steady speed as possible. Then let car rest till cold. Repeat the above sequence a few more times and those readiness should set if there are no issues.
Usually I can get those flags (evap + cats) set within at most 3 days of driving with mixed local and highway traffic.
Old 11-11-2015, 01:19 PM
Ahsai
Ahsai's Avatar
Thanks. I'll try this next time and report back.
Old 11-11-2015, 01:31 PM
JayG
JayG's Avatar
where in the hell do you find a place to drive like that?
Old 11-11-2015, 01:38 PM
FRUNKenstein
FRUNKenstein's Avatar
Unlike you SoCal types, he lives in flyover land.
Old 11-11-2015, 02:11 PM
5CHN3LL
5CHN3LL's Avatar
You'll need to rent Auto Club Speedway for a day. Let us know what day you choose so we can enjoy the track once your car is finally smog ready.
Old 11-11-2015, 02:33 PM
JayG
JayG's Avatar
So I would have to go to hell then
great minds think alike
Old 11-11-2015, 02:39 PM
gnat
gnat's Avatar
While a bit on the messy side the best method I've found involves a chicken, chanting unpronounceable words, and a knife...
I think it took about 3 months to get my Cayenne to cooperate the last time it got reset.
Old 11-11-2015, 02:55 PM
JayG
JayG's Avatar
sounds like a plan.
Can you post detailed directions?
Old 11-11-2015, 03:15 PM
BTERRY1
BTERRY1's Avatar
I did the above sequence last Monday prior to smog and it worked like a charm. shop reset everything changing my expansion tank. Key is not to exceed 3K RPMs the entire time or 60 MPH for the last part of the sequence. I did the first part on access roads close to my home then the second part on the freeway at 430 am when traffic was minimal. got passed by a bunch of semi's who i am sure where wondering who is this loser in the slow lane going 55 in a 911.
Old 11-11-2015, 03:27 PM
joe-1972
joe-1972's Avatar
That is the guideline for what the CPU is looking for to run the tests... If you can stay on speed it does it faster... If not it will also work cumulative... I had to reinstall my Cats for my ILLINOIS testing... I followed the guidelines more or less and never ran over 3k or over 60mph... Most of the monitors reset to clean... Next day same idea but mixed city and HW driving... Not pushing it and turning on the AC for a while then the Defroster... All my monitors finally reset to Green. That was on last Saturday night... Then I jumped on it on Sunday and she pulled the dash light and a bunch of codes! I should have left her in the garage till I could take her to the test center...
Moral of the story (Monster run on sentence). Get an ODB Bluetooth scanner... Clear out all your codes, lights, stored data and then follow the reset program as best as you can... SOON as everything resets to Green TEST the car as soon as possible!
Then pull into the garage and pull the cats back OFF!
Old 11-11-2015, 03:47 PM
Ahsai
Ahsai's Avatar
So you hold down the clutch for 5 min in the idle in gear step?
Old 11-11-2015, 04:04 PM
BTERRY1
BTERRY1's Avatar
i idled in neutral. i read somewhere if it is a tip car you leave in gear and idle for 5 min
Old 11-11-2015, 04:14 PM
Ahsai
Ahsai's Avatar
Thanks. That makes a lot more sense for stick shift
Quick Reply: readiness monitors
