Cigarette lighter fuse blown.
Does anybody know which fuse is the fuse for the cigarette lighter? The actual lighter won't pop out and I'm sure it's because the fuse is blown.
Just a thought. Before you go checking all your fuses. Hold the lighter fully in for about 20 seconds then manually pull it out. If it's warm or even red, then it's not your fuse blown but a fault on the actual lighter.
