996 Forum 1999-2005
removing airbag warning on sun visors
Old 09-24-2003, 10:45 AM
mtksurfj
mtksurfj's Avatar
Default removing airbag warning on sun visors
On my car there are ugly warning labels on the sunvisors... they apear to be painted on (not stickers). How do I get them off?
Thanks,
Ross
Old 09-24-2003, 11:21 AM
Palting
Palting's Avatar
Alcohol, Q-tips, and some patience. Takes about 20 min per. There will be a residual darker area where the sticker was. Use a Trim restorer/detailer like Mothers or ForeverBlack. It improves the color, but still noticeable. Better than that horrendous sticker.
Old 09-24-2003, 12:48 PM
mtksurfj
mtksurfj's Avatar
are there aftermarket replacement visors?
Old 09-24-2003, 01:07 PM
Palting
Palting's Avatar
I understand that the ROW cars do not have a warning label. You can probably order one from Carnewal.
Old 09-24-2003, 04:41 PM
01 C4 Cab NYC
01 C4 Cab NYC's Avatar
Yeah,
Gert does carry visors w/o the stickers....
Old 09-24-2003, 04:48 PM
Eric - Plug Guy
Basic Sponsor
Eric - Plug Guy's Avatar
DO NOT USE REGULAR ALCOHOL.
Buy denatured alcohol at your local hardware/supply house.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Old 09-24-2003, 06:48 PM
Palting
Palting's Avatar
Heh-heh. My bad. Use DENATURED alcohol. Thanks Eric. Reserve the alcohol for drinking
Old 09-24-2003, 07:47 PM
DonW-Cape Cod
R.I.P.
Lifetime Member
DonW-Cape Cod's Avatar
I heard that removing labels voids the warranty!
Old 09-25-2003, 11:04 AM
path
path's Avatar
I know this sounds crazy but I think my sunvisors are leather. I bought the car used and the guy before me order full leather, and also optioned for leather visors. I'd like to take the stickers off too. If the visors are leather will the denatured alcohol harm the leather? Thanks.
Pat
Old 09-25-2003, 01:28 PM
DonW-Cape Cod
R.I.P.
Lifetime Member
FWIW, I bought my 02 Cab with full leather option in Met Blue. Order guide says "sunvisors in leatherette." Even though the visors themselves are Met Blue, here is no leather "aroma" in mine and the texture and grain of the visors is different than the leather covered items.
Old 09-25-2003, 06:36 PM
Karl S
Karl S's Avatar
I have leather visors ( it is a separate option from full leather, so you can check the option codes in your trunk to be sure) and my warning sticker peeled off pretty easily. I may have used a little heat but not much. This is on the underside. The sticker on the other side is on the plastic mirror cover and I haven't figured out a good way to get that one off.
Karl
Old 09-25-2003, 10:55 PM
path
path's Avatar
Karl s,
I have two option codes that I can't figure out. After much research I still haven't found the answer. Do either numbers, 9981 or 9991, correspond to the leather visor option? If not, does anybody have any idea what they are?
Pat
Old 09-25-2003, 11:07 PM
Palting
Palting's Avatar
There is no way you can mistake the cheap vinyl sunvisor for a leather one. It is one of my biggest pet peeves with the full leather option. Everything in leather, except this cheap obviously plastic thing that sits just above eye level while driving. The only thing that is preventing me from buying the Porsche leather sun visor separately is that I have an even bigger disgust for the outrageous prices Porsche options and aftermarket items command. A separate $500 for leather sunvisors that should have logically been included in full leather option? EGAD!!!!
Old 09-26-2003, 02:15 AM
DonW-Cape Cod
R.I.P.
Lifetime Member
Shame on me! I thought "FULL" meant FULL leather. Never checked that other option. At the time of the order what was another $500. But now...no way! At least they're blue
Old 09-26-2003, 05:38 AM
Mr. C4
Mr. C4's Avatar
Live with the sticker rather than risking damaging the visors! I'm a lucky guy, don't have the stickers!
Ciao,
Johannes E.
Quick Reply: removing airbag warning on sun visors
