996 Forum 1999-2005
Black foam in 2003 C2 air box
Old 09-11-2015, 06:20 PM
fpb111
fpb111's Avatar
Default Black foam in 2003 C2 air box
Does anyone know the part number for the black foam in the bottom of the air box?
I was vacuuming the dirt out during a filter change and some of that foam got sucked up.
It is a little like the HVAC foam. Know the reason for it in the first place?
Old 09-11-2015, 06:25 PM
Ahsai
Ahsai's Avatar
Sounds dampening is my guess.
Old 09-11-2015, 06:30 PM
Fracture
Fracture's Avatar
Ignore it,... I had the same situation and called Porsche
as the part was not listed
Parts department asked one of the techs and then said to remove and discard
Old 09-11-2015, 07:39 PM
hotelguy
hotelguy's Avatar
it is important....catches water so it does not go into the TB and engine
Old 09-11-2015, 07:51 PM
Rubik
Rubik's Avatar
Ask Hurdi and I'm sure he'll know where to find it in Home Depot. No need for a part number for something trivial like that.
Old 09-11-2015, 11:54 PM
5CHN3LL
5CHN3LL's Avatar
Oh crap, I don't have any black foam in my airbox! That explains the repeated hydrolocking.
Old 09-12-2015, 01:22 AM
fpb111
fpb111's Avatar
Do you leave your car under the down spout during monsoons? Wasn't it Navy that did that and got a new engine from his insurance?
Old 09-12-2015, 01:27 AM
fpb111
fpb111's Avatar
I also guessed cut down on resonance and water vapor/condensate buffering.
One person on Renntech just cut some foam air filter material to shape and mounted it under the grid.
Old 09-12-2015, 12:41 PM
redriderrick
redriderrick's Avatar
I looked at mine recently and put it back (didn't see a use for it), but then thought about the water issue. Next time I'm in there, I'm going to trim a green ScotchBrite pad to fit. It should work the same and be more durable. Of note is the need to make SURE it's well-fastened under the grid on the bottom of the air box.
Quick Reply: Black foam in 2003 C2 air box
