996 Forum 1999-2005
Coolant poluted with tap water
Old 08-31-2015, 12:52 PM
JayG
JayG's Avatar
Default Coolant poluted with tap water
Had to add approx 3 liters of tap water to my coolant tank due to a leak at the water pump while driving home
As I am about to change the water pump, do I need to flush and refill with new coolant/distilled water mix, or just add some more of the proper coolant?
Old 08-31-2015, 12:54 PM
LexVan
LexVan's Avatar
Received 5,388 Likes on 2,509 Posts
Yes. Flush and refill. You need about 3 gallons Porsche coolant and 3 gallons of distilled water. Next time, top off with bottled water, that would have been a better choice than tap water.
Old 08-31-2015, 01:09 PM
joe-1972
joe-1972's Avatar
http://www.target.com/p/market-pantr...purified+water
.89 cents a gallon... cant go wrong...
5CHN3LL
5CHN3LL's Avatar
Jay, if you want to borrow my AirLift system for the flush-and-fill, let me know.
Old 08-31-2015, 06:55 PM
JayG
JayG's Avatar
Yes, that would be great! I was just going to post asking if anyone had one available
I'm gonna be DIYing this weekend
Please PM me with details
Old 09-01-2015, 11:24 AM
joe-1972
joe-1972's Avatar
That airlift system is the way to go... Good luck... Have fun... Any enjoy the time you spend working on your own car!
Old 09-01-2015, 12:03 PM
Macster
Macster's Avatar
That was some leaking water pump. It is a wonder it did not fail catastrophically. I have to stress that it really is risky to drive with a known bad water pump. The unit can go from noisy/leaking just a bit to the point the impeller blades make contact with the engine block and then you can have some real problems. Or the thing breaks and that ain't good either.
As for the question about the coolant after adding tap water no one can say for sure but Porsche advises using distilled water with anti-freeze. While there are some owners who have used tap water the numbers are so small we have no real data on this.
Thus to play it safe draining the coolant and refilling with a fresh batch of coolant consisting of the proper ratio of anti-freeze and distilled water is best.
An added benefit is the new water pump and the engine and its cooling system components start out with new coolant with all its ability to resist corrosion active and on the job, so to speak.
Old 09-01-2015, 04:32 PM
JayG
JayG's Avatar
Yea, we all have 20-20 hindsight.
Probably should not have driven it home
Quick Reply: Coolant poluted with tap water
