What is airbag fault code 01 ??
Recently bought a durametric to diagnose and turn off my airbag warning light. I expected it to be something like seat belt terminal corrosion or under the seat cables, but the fault code is "01". What the heck does that mean?? Do you guys think it would help to unplug then reattach the airbag module?
Here is what it says from the manual:
Update: I am STILL trying to troubleshoot my airbag light which is triggering fault code 01.
First, I checked the fuse as specified and replaced it with the spare even though it looked okay. Then I disconnected the airbag module in front of the shifter and sprayed the connections with electrical contact cleaner. Airbag light and fault code was still coming back on every time I reset it with my durametric.
So then I bought an inexpensive used airbag module from the same year & model (2002 C2 Cab) thinking that the original module might have an internal defect. Swapped the module and the light/fault code still won't go away.
My latest effort was to remove the cluster and spray all of the connections with electrical cleaner. During this process, I also inspected the harness as best as possible, looking for shorts or crimped wires. Although it's pretty tough to see anything as the wiring is bundled in a cloth loom except for the last little section where it enters the plugs. Light/code is still on.
Help!! I am totally at wits end with this! Is it possible that the short/defect is actually inside the instrument cluster itself?? Seems like I have tried everything else. Unlike the Mk1 cars, the Mk2's have sealed clusters with LED (I think?) warning lights so there is no airbag bulb/socket available to inspect.
I would be beyond appreciative for any suggestions. Thanks!
I would ask: With the ignition on, does the airbag light come on in the dash?
I bet the answer is: No
If so, then you have to check the bulb, if that's good, then using the wiring diagrams, check continuity from the control module to the bulb and from positive to the bulb. You'll find the problem in there, shouldn't be hard.
Captain Obvious
Super User
Super User
The 3 steps in the repair manual are pretty clear what needs to be done. Until you do all 3 of them and the light still stays on, THEN it's time to ask for additional help.
I did step #1.
There is no step #2 in my case as the "bulb" is a permanent LED on MK2 cars. Bulb is lit all the time, both with key turned on & engine running.
Regarding step #3, I did visually inspect the wiring leading from the module to cluster but there isn't much to see as it's all loomed. Thanks to Ahsai, I learned that pin #7 is the red/yellow wire so I will check that with a continuity tester as soon as time permits.
Reply edited: Once you disconnect the connectors of the red/yellow wire from *both* the cluster and airbag control module to isolate it. You can then check for continuity.
I did step #1.
