Power Seat Control Knob - Where to find a replacement
#34
I need one
I am new to the forum, but not new to these cars.
I have a 2002 C4S with a missing seat adjustment **** on the driver's seat. Ordered what I thought was the correct replacement only to find out it is for a manual seat adjustment switch. I understand I need to order a complete switch for $400+ to get the ****.
Thread sounds like somebody has reversed engineered to fabricate a replacement or has a **** by some other means.
Any help would be appreciated. Not sure how to PM the guy identified as ER.
KellyMN (08-01-2021)
#37
I was able to return the switch which was for manually adjusted seats as I needed the **** only for the electric 4-way adjustable seat. The **** I need is only sold together with the complete switch for $400+. If you need the switch for a manually adjusted seat it should still be available from Porsche since I bought it (and then returned it) within the last year. Good luck.
#39
Any luck?
Thread revival! - Unlike some folks in need of the ****, I'm missing #17 pictured below which centers the **** and allows the seat to lower. I've called Porsche to find out this part is discontinued. Any suggestions is greatly appreciated.
#40
I'm in the same boat with my 2016 997. Need the passenger side adjustment ****. Though upon closer inspection, it seems as though a white plastic connector piece is what actually broke.
