996 Forum 1999-2005
2003 C4S Battery Drain
Old 05-25-2015, 10:58 PM
Rpompea
Rpompea's Avatar
Default 2003 C4S Battery Drain
I am trying to identify a draw that kills my battery withing about 5 days.
No visible items staying on, confirmed frunk & glove box lights are off, interior lights off and no accessory items are on
New Battery and good charging system, vehicle locked when parked.
I will do the draw test this weekend but I was wondering if there is a known cause.
Old 05-26-2015, 12:49 AM
Ahsai
Ahsai's Avatar
Any aftermarket electronics, phone chargers, etc connected? It seems like you are looking at ~0.5A draw. Do you have a DC amp clamp? Could be bad diodes in the alternator drawing current if you tested all the fuses already (alternator is not fused).
Old 05-26-2015, 12:53 AM
Ahsai
Ahsai's Avatar
DC amp clamps are quite affordable these days btw
Andoer UNI-T UT210E True RMS AC/DC Current Mini Clamp Meters w/ Capacitance Tester - - Amazon.com Andoer UNI-T UT210E True RMS AC/DC Current Mini Clamp Meters w/ Capacitance Tester - - Amazon.com
Old 05-26-2015, 07:04 AM
Rpompea
Rpompea's Avatar
ipod adapter and radar detector removed already. good tip on the amp clamp, I will pick one up so when i get started I have the right tool.
Thanks for the alternator tip, I will check that out as well by isolating while checking for draw.
Old 05-26-2015, 01:05 PM
Ahsai
Ahsai's Avatar
There's a fat cable (actually multiple cables in series) from the battery leading to the engine compartment "+" jump point. Put the amp clamp around that cable and you will see the draw from the alternator, if any.
Old 05-28-2015, 04:19 PM
Schnell Gelb
Schnell Gelb's Avatar
Suggest you search for recent thread which identified problems with the "Y connector".
Quick Reply: 2003 C4S Battery Drain
