2001 996 Drop link torque specs
According to my Bentley manual, sway bar link (drop link) to sway bar tightening torque = 50Nm.
I could not find any value for the upper bolt torque value, but it wouldn't be much different - I think I used slightly less when I replaced my drop links. I also used Loctite on the threads which Bentley didn't mention, so it may have been overkill....
If its anything like my Boxster S drop links (which I think it is), its very simple - no shock removal required. The drop links are mounted between the shock body and the (anti)sway bar end.
