View Poll Results: Which do you recommend for multiple track days and DD?
Bilstein PSS10
6
35.29%
KW Variant 3
2
11.76%
Ohlins DFV
8
47.06%
Other
1
5.88%
Voters: 17. You may not vote on this poll
Quick Poll: For C4S Track/DD - KWV3 vs PSS10 vs Ohlins DFV
I know this has been asked many times before, just looking for a fresh 2015 poll now that a lot of owners have had them for a few years. I've read all of the reviews here and still can't decide. I'd like to hear from some of you in similar situations that use this as a second car and get out to at least 5 PCA or other track sessions in Group A or B.
For C4S Owners, I've collected the best prices I could find:
PSS10s for $3000
Adjustment:
Height - Yes
Damping - Yes/No - Adjustable presets with Rebound
Rebound - Yes/No - Adjustable presets with Dampening
Spring Rates:
Front: 260 lbs
Rear: 540 lbs
Pros:
Proven for many street applications.
High quality struts
Lowest Spring Rates - Street
Cons:
Lowest Spring Rates - Track
KW V3s for $3300
Adjustment:
Height - Yes
Damping - Yes - individually
Rebound - Yes - individually
Spring Rates:
Front: 230 lbs/Progressive
Rear: 630 lbs
Pros:
Complete adjustability
High Spring Rates - Track
Cons:
High Spring Rates - street
Ohlins DFV for $3500
Spring Rates:
Front: 400 lbs
Rear: 686 lbs
Adjustment:
Height - Yes
Damping - No
Rebound - Yes
Pros:
Dual Flow Valving - Arguably the best shocks out of the group
Cons:
Non-adjustable compression damping - DFV is preset with rebound
Thanks all for your input!
PSS10s for $3000
Adjustment:
Height - Yes
Spring Rates:
Front: 260 lbs
Rear: 540 lbs
Pros:
High quality struts
Cons:
KW V3s for $3300
Adjustment:
Height - Yes
Spring Rates:
Rear: 630 lbs
Pros:
Cons:
Spring Rates:
Front: 400 lbs
Rear: 686 lbs
Adjustment:
Height - Yes
Damping - No
Rebound - Yes
Pros:
Cons:
I'm really leaning towards the Ohlins. The spring rates do not appear to be high enough without rebuilding on the others. Ohlins can handle 30% more before revalving however higher rate springs direct won't be available until later this summer. Revalving is $120 a corner if needed. Contacting Eibach direct might be able to provide higher rate springs faster/for less.
Ohlins. No 996 experience but installed on my Ducati and Aprilia. Wish they were available when I did coil overs. My 4S has H&R with tarret camber plates. What use is priority? Track or street?
Just left him my number.
Turns out Leo is no longer with Vivid Racing, but spoke to Sean on the phone and he honored the great price that Leo gave me 2 months ago.
Went with a set of KW V3s. You might have seen these on eBay with unmarked numbers. I called the owner and KW - they were valved and sprung for the C4S. Got lucky.
Final Suspension Setup:
PowerFlex Bushings - All front and rear bushings
KW V3s
Tarret Monoballs
Eibach Sway Bars
Custom Endlinks
Torque Solutions Dogbones
Torque Solutions Toe Links
Track videos and reviews coming soon.
KW V3s
Tarret Monoballs
Eibach Sway Bars
Custom Endlinks
It's interesting that KW's remote reservoir are welded on directly instead of having a line. Wonder if cost savings on their behalf factored into it.
Did you go with the old or new version of the Eibach sway bars?
Also no engine mounts?
I wasn't aware there was a difference between the Eibachs. Just ordered the front and rear set. They were noticeably thicker and stronger than stock.
Engine mounts were a vast improvement. I went with Function Firsts in red. My old ones were cracked causing rough idle and from looking at the rear, both exhausts were hanging about an inch too low. New mounts solved both.
I think they do this purposely for autocross. Remote reservoirs are not allowed in certain classes.
Older Eibachs were smaller and non adjustable. See if your bars have multiple holes on the ends to see if it's the newer ones.
Oooh...you got the high hp versions which are the racing red TypeRAMGSMGTRGT3RSR versions.
Interesting about the autox. Does this apply to SCCA?
The Eibachs are adjustable. There are 3 endlink points (firm, neutral, soft). The H&Rs have 5 and are also about twice the price.
LOL on the engine mounts. You can pick any color, I'm partial to red racing thingies
