X77 Air bag steering wheel combination of carbon and interior color leather
thanks! By any chance is the litronic headlight an option that appears under the frunk? I have them but no option code indicating it came from the factory.
I think the code for Litronic headlights is 601 and it should appear on the option sheet.
Realize they may have been added by a previous owner - it's a fairly common upgrade.
Rick
You can tell if the Litronics's were added on afterwards as they will not have the self leveling feature due to complexities in adding it afterwards. Just check the pass side control arm for a linkage assembly going to a sensor. This is what controls the leveling in factory HID system. If you see it there, the lights most likely came that way.
