RUF 996?
They did! It was labeled RGT and was based off the GT3. Lots of goodies on the car including upgraded camshaft and exhaust; it hit about 380HP and had a top speed of 190MPH. It came in RWD but there was an option to AWD as well.
They offered both FI and NA version 996 including a m96 based supercharger version.
Models offered were:
RTurbo
RGT-RS
RGT
RKompressor
There's a member here that has a genuine yellow 996 RGT. He's posted in the pic threads a couple times.
RTurbo
RGT-RS
RGT
RKompressor
I was thinking if RUF every modified a regular 3.4 or 3.6 NA 996 motor.
If so did they address some of the 996 early issues or have similar issues in there modified cars.
Ruf did have a boxster where they put the 911 3.4 and later 3.6 and called them 3400S and 3600S respectively. I'm not sure what, if any, parts of the engine internals have been modified.
Here are some pics of mine.
Awesome car. GT 3 Motor.
It would be interesting to know what modifications they did. I am sure RUF would have addressed some of the issues.
On the rgt, they seems to have addressed some of the issues later discovered with the fuel pump and the rubber lines. Mine have all braided lines from factory. They however did not identify the coolant fittings issue from factory so I had that done last year as preventative maintenance. They also didn't realize the Porsche lsd would not hold up so i now have a guards.
Former Vendor
The cars they built generally had engine conversions with larger stock engines. I have 3400S Boxster here now with a failed 3.4 engine. The car is very well built, but it had a factory reman 3.4 996 engine installed that made it 49K miles before failing under the original owner.
Former Vendor
I learned long ago that the one ship that will not float, is a partnership.
