996 track car part out
996 Track Car Parts Sale! All parts will be ready for shipping. Price does not include shipping. Shocks were on car about 2000 after rebuild.
RSS Semi solid engine mounts $250
Function first transmission mount insert ( black ) $100
Porsche X51 oil pan baffle $150
Zunsport Grilles $225
Numeric Shifter $475
JRZ RS Suspension rebuild 1 yr ago ( 2000 miles ) $2200 includes:
2 Front Double Adjustable RS Damper Assemblies
2 Rear Double Adjustable RS Damper Assemblies
2 Front 900 lb. Rate Main Springs
2 Rear 800 lb. Rate Main Springs
4 Tender Springs
4 Upper Spring Hats
4 Lower Spring Seats
4 Main/Tender Spring Spacers
GT3 Swaybars Front $225, Rear $225
GT3 Lower conrtol arms. Front $325 Rear $325
Tarrett Camber Plates Front $325, Rear $325
Tarrett Drop Links Rear $175
Front Drop links $150
Rear upper control arms $125
Adjustable Front Tie Rod with bump steer $100
Toelinks with bumpsteer $225
*sold as a total suspension package. $3000
Cat bypass $550
Sparco Evo II seats on brey krause side mounts and sliders direct bolt in. ( out of date ) $350 each
Sparco 6 point harnesses ( out of date ) free with seats
Das Sport 996 Roll Bar $850
1 set Fiske Wheels $2000
Front tow hook $60
Tie downs $40
Located in Virginia Beach. Can deliver to VIR.....
Pictures in the parts market place add.....
4 Tender Springs
4 Upper Spring Hats
Cat bypass $550
Front tow hook $60
Tie downs $40
this is a bargain for $3k you get a really nice setup !
good luck with the sale, this should not last long.
All these parts are a great selection.
sad to see you had to part the car out.
