996 Forum 1999-2005
Bluetooth OBD Monitor / iPhone App
Old 03-20-2017, 02:01 PM
Gator996
Gator996's Avatar
Originally Posted by wyovino
It's the app that stores the data, so any compatible ODB II device should be able to log information. The Vgate unit with DashCommand will log data.
Perfect, thanks!
Old 03-20-2017, 02:16 PM
wyovino
wyovino's Avatar
I posted this in another thread about scanners but I think this is a good place for it as well.
Follow these steps so that you'll still be able to use Pandora, Waze, and other Internet-based apps while using the WiFi scanner. If you don't, the iPhone will try to access the Internet via WiFi instead of cellular.
Plug the unit in and turn the key on. You don't need to start the engine.
If the unit is not on (lights should be lit), turn it on via the power button.
In iPhone Settings, go to Wifi and select the "V-link" WiFi network (if using the VGate scanner, or chose the proper network for your scanner).
Select "Static" and enter this info:
IP Address: 192.168.0.11
Subnet Mask: 255.255.255.0
Router: 192.168.0.10
This will tell the iPhone not to try to get to the Internet via the V-Link network.
Old 03-20-2017, 02:44 PM
Gator996
Gator996's Avatar
Fantastic information that I would not have otherwise known. Thank you sir!
Quick Reply: Bluetooth OBD Monitor / iPhone App
