Good week in the 996 forum... - Page 4 - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 11-11-2013, 07:09 PM   #46
Gator996
Gator996's Avatar
I used the Pennzoil blinker fluid on my last annual flush. My turn signals are noisier than ever now. Should I go with Mobil 1 and if so, what weight?
Gator996 is offline   Reply With Quote
Old 11-11-2013, 07:42 PM   #47
Capt. Obvious
User
Capt. Obvious's Avatar
Joe Gibbs has a new all-in-one blinker/muffler bearing/coolant/cooking oil that you should be using. If you don't, your car probably won't make it past 50k miles.
Capt. Obvious is offline   Reply With Quote
Old 11-11-2013, 07:57 PM   #48
Gator996
Gator996's Avatar
Good to know Capt. I will put a 50gal order in with Summit Racing tomorrow.
Old 11-11-2013, 08:21 PM   #49
DreamCarrera
User
DreamCarrera's Avatar
Quote:
Originally Posted by Gonzo911 View Post
Does anyone know where I can buy Porsche OEM air for my tires?
Porsche OEM air??? I've never heard of this before...I'll bet that's why my last set of rear tires only lasted 5,000 miles.
Do Indy's carry this air or do you have to go to a P stealer? I'll just check with my dealer because the Indy season is over and I don't want to wait until spring(when the new Indy season begins) to get this air. Actually, maybe George Costanza can help me. Is he still working on the Penske file???
Quote:
DO NOT do this. 50 gallons is way too much...sure you need to change the fluid every 250 miles or 2 wks(whichever comes first) but unless you put a lot of miles on your car you will never be able to use all of that fluid before it goes bad. I've heard that the fluid absorbs moisture even sitting in an unopened container and only has a shelf life of 3 wks...just sayin'.
BTW, how do you add this fluid to the muffler bearing? Yes, I've done a search but I still can't seem to find it. I just poured a little bit of the fluid on top of both muffler cans but now my car smokes like a bitch...HELP!!!
DreamCarrera is offline   Reply With Quote
Old 11-11-2013, 08:37 PM   #50
Gator996
Gator996's Avatar
Well, I figured that 50 gals would be enough for the frequent fluid changes plus my daily frying of various foods, including Oreos.
You need a special tool for the muffler bearing. The tool is only .36 at Harbor Freight but you must have it programmed by the dealer for 274.79.
Old 11-12-2013, 12:18 AM   #51
mcbit
mcbit's Avatar
Quote:
DO NOT USE AIR IT WILL VOID THE WARRANTY ON BOTH YOUR TYRES AND YOUR CAR
It is well known that use of air degrades handling, gives a 5000 mile tyre life and necessitates refilling at 100 mile intervals.
For N rated tyres please use N2 (Nitrogen), see related TSB on carrying a Nitrogen cylinder in the frunk.
Updated PET Part No 996 997 991 S16 Savanna
mcbit is offline   Reply With Quote
Old 11-12-2013, 12:41 AM   #52
Cuda911
Cuda911's Avatar
OK, a real question here... I'm sure it's been covered 12,000 times before but I'm too lazy to search....
I've always checked my oil with the dip stick. For a few days running, there's been this moronic thread about the dipstick shedding metal flakes into the oil , thus causing your engine to implode or explode or fall out or something. Totally stupid.
Anyway, for the first time ever, I decided to try using the on board computer oil level check. It started a timed countdown that indicated it would take one hour! I waited three minutes, then canceled the oil check. What's the deal here?
Cuda911 is online now   Reply With Quote
Old 11-12-2013, 12:54 AM   #53
pfbz
pfbz's Avatar
Is there a place to buy a replacement a55hole repellant cartridge for the rear spoiler?
Mine must be empty...
In the past week I've had a preponderance of tools driving powerhouses like Mitsu Eclipses Dodge Darts cut across several lanes of busy freeway traffic just to pull up along side of me and show me their awesome capability to accelerate from 75 to 99, then hit the brake, repeat.
As an alternative, maybe I should just buy an Eclipse and join the tool club?
pfbz is offline   Reply With Quote
Old 11-12-2013, 12:56 AM   #54
pfbz
pfbz's Avatar
Quote:
Originally Posted by Cuda911 View Post
...I decided to try using the on board computer oil level check. It started a timed countdown that indicated it would take one hour! I waited three minutes, then canceled the oil check. What's the deal here?
Are you using a Porsche approved oil? I'd try that first.
Old 11-12-2013, 12:58 AM   #55
Cuda911
Cuda911's Avatar
Quote:
Not sure... is Crisco Porsche approved?
Old 11-12-2013, 01:03 AM   #56
pfbz
pfbz's Avatar
Nope. Only Pflanzenfett. For Winter use only of course...
Old 11-12-2013, 01:53 AM   #57
mcbit
mcbit's Avatar
Real answer too! If I stop the car, turn off the ignition and turn on again it will generally show 4 - 5 minutes. If I stop at a gas station and fill up before switching on the ignition again, generally indicates about 5 - 6 seconds. Haven't tried it cold but I imagine the results may be interesting.
The flaky dipstick sounds like it has been posted by a flaky dipstick to me. I call BS!
Old 11-12-2013, 05:39 AM   #58
Cuda911
Cuda911's Avatar
Thanks, McBit!! I was using summer blend Crisco in a cold engine, hence the slow measurement time. I have it scheduled to get it swapped out with Pflanzenfett. My error was to assume that just because there is no difference between winter and summer weather here, I didn't need to change oil type now that winter approaches nigh. At least my indie only charges $850 for that (labor), plus another $1,200 for an OEM filter, so not too bad at all.
Winter steel-studded tires go on next week too. I hope they aren't too loud on the freeway.
McBit, my tires are rated N4. Does that mean I need to use double-enriched nitrogen?
P.S. You spelled "tires" as "tyres". That is illegal in our country, even if done in proxy mode via internet. I see you are in UAE, but shall assume low Al Qaeda influence for now. I only ever see them driving Toyotas on CSPAN.
Old 11-12-2013, 09:44 AM   #59
Adker
User
Adker's Avatar
No need to waste money, it is a easy DIY project.
Adker is offline   Reply With Quote
Old 11-12-2013, 09:55 AM   #60
DBJoe996
DBJoe996's Avatar
I think I saw one of those 50 gal. vats in one of KrazyK's garage pictures! I have a question - I have 127,500 miles and I was wondering...is it time for an oil change? Should I include a new or used filter? Doesn't checking the oil with the dipstick create friction in the dipstick tube and thereby contaminate the oil every time it is checked? I never put air in my tires except Porsche approved air, I lubed my muffler bearings with JB Weld (was that a mistake?) and I also found that the condenser and radiator bearings required a special little known Porsche lubricant only available at a special tree outlet in the Black Forest. Look that one up! Cheers!
DBJoe996 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
How old are the 996 owners ? 996_North 996 Forum 262 Today 12:05 AM
Tool loan registry: Include item(s) and location 5CHN3LL 996 Forum 36 03-16-2017 01:07 PM
Track videos thread 911SLOW 997 GT2/GT3 Forum 329 12-22-2016 02:25 AM
1RS Picture Thread CRex 991 GT3 GT3RS and 911R 7 08-15-2015 04:54 AM
FS: Tarret 996 Tow Hook rickdeaconx Parts Marketplace 2 08-12-2015 02:25 AM
Tags
5chn3ll is not straight, 996, blow me a$$hole, bruh, bullet, cameron, car, counselor, diaz, erection help, finger sump, forum, frunkenstein, good, holes, jeunesse dorée, kcattorney not funny, porsche, scene, spatula, troll: now with two k's, wd-40, week, well_lubed_sphincter, yoav gilad is a douche
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 1998 - 2015 Rennlist.com
  • Ask a Question
What's your question?
Send
