View Poll Results: Has YOUR car suffered an IMS failure
Voters: 1591. You may not vote on this poll
IMS bearing failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2 failure mode)
#796
car is in the shop for IMS. Around $2500 (tiptronic). Going to get the AOS done along with whatever else (coils, belts, etc) and new tires. Going to get a LN bearing. Even though the car has 378xx miles given it hasn't been driven much in 17 years I didn't want to risk engine failure and what would be a loss of the car (doesn't make sense to get a new engine or engine swap). Hopefully after this wallet hit she's good to go to be driven hard for a bit. Looking forward to getting her out in limerock park for some DE come spring/summer
#797
Former Vendor
For my planned use of the car I expect this to last the life of the car.
If you plan to go a very long time (calendar time) with a product, shorten the service intervals and approach with care. Corrosive wear is the thing to avoid, so watching TBN levels in the oil will help with that more than anything.
#798
Hey Jake, I have put in a magnetic drain plug and I plan to change oil twice a year, before summer and before winter. I have done this with my last 2 Corvettes with low mileage and almost no winter mileage with great success. Is this a good schedule in your mind? Of course, I change the oil filter as well.
#799
Former Vendor
I find that some of my customers could go longer than 6 months on an oil service, while others with the exact same car, and the same engine can't make it more than 4-5 months without the oil losing TBN, or having high TAN.
If you are going to ask the bearing to live longer than the recommended service interval in calendar time, then you'll need to do a little bit more.
#801
My dual-row IMS failed at 75k. It was in the "3rd stage of failure" as Mr. Raby described above, so it was just barely caught before destroying the engine. Did a full teardown, but the internals looked (and measured) perfect. Mobil1 0W40 might not be the best possible oil for our car, but it did a pretty spectacular job for 75k miles on mine. The piston rings even still had most of the black coating.
#802
The less it's driven and the less frequent the oil is changed (even though the miles don't justify frequent oil changes) - the more the bearing is likely to fail. Low mileage and any periods of storage appear to be just as much a contributing factor as high mileage.
#803
2000 C4 Cabriolet. For peace of mind I had mine replaced last year at 100,000Km by Flat 06 in Cagnes sur Mer. The cost for the replacement with a ceramic bearing, new RMS and oil and filter change was 1800 euros and I had the car back the same evening. I cut the old bearing open. It was dry with just granulated lube/carbon remaining. Wear was appearing, probably no more than another 4 or 5,000Km and BANG! I really feel that I dodged a bullet there. Some posters here seem to be pinning their hopes on double row bearings... take a look at mine.
#804
Looks to me like the factory lube was very much compromised by oil, which is what JR was referencing above if I'm not mistaken. Removal of lube and subsequent lack of proper lubrication compromising the operating condition of the bearing. Chronically low TBN = chemical deconstruction of certain vulnerable internals, like the ball bearing imsb.
#806
2000 C2 with a 12/99 build date. I was thinking of gambling and just leaving the IMS alone given it was a dual row but because the car has just barely 38k miles I decided to get it done while getting other work done as well. Here is the dual row that came out. The mechanic said that there was some oil leaking from the back seal.
#807
1 Post
2000 C4 50k miles -- Oil Filter Metal
Add me to the failure list... bought a 2000 996 30k miles in 2015 (Garage Queen). Put 20k miles on it; multiple oil changes; filter busted each time -- no metal; Clutch replacement at 50k miles; IMS Solution ordered (keeping the car); Oil changed about 5k ago -- drained oil -- METAL. I think I caught it in time. Pulling the bearing next week. IMS soltuion arrives Tuesday.
#808
#809
