996 Forum 1999-2005
View Poll Results: Has YOUR car suffered an IMS failure
Yes, the IMS failed
8.67%
No issues with IMS
91.33%
Voters: 1591. You may not vote on this poll
IMS bearing failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2 failure mode)
Old 06-06-2013, 02:26 AM
  #181
Cuda911
Cuda911's Avatar
Default IMSB and RMS
IMSB and RMS. Both looked perfect, at 100K on the car, but I upgraded anyway.
Old 06-06-2013, 10:18 AM
  #182
alpine003
alpine003's Avatar
^^^ isn't that procedure reversed? most pull the tranny instead of the motor...
Old 06-07-2013, 12:28 AM
  #183
Cuda911
Cuda911's Avatar
Ah, tranny was pulled too! Had a laundry list of items I wanted to replace for PM.
Old 06-10-2013, 10:06 AM
  #184
bigmsm
bigmsm's Avatar
2001 C4, 70k miles; no issues. Thinking about proactive replace using a new system that direct injects oil to IMS to keep lubricated. Waiting to see cost. http://tinyurl.com/lmuqb5d
Old 06-14-2013, 04:26 PM
  #185
ArniO
ArniO's Avatar
2003 C4, 60k miles; No issues. Replaced with LN bearing whilst reclutching. Old bearing was still perfect.
Old 06-26-2013, 06:42 PM
  #186
MLANDINGIN177
MLANDINGIN177's Avatar
2000 C2, 98K no IMS issues
Old 07-01-2013, 02:16 AM
  #187
CrossT
CrossT's Avatar
No issues. 1999 mk1. 65k on motor
Old 07-02-2013, 02:20 PM
  #188
sjg1138
sjg1138's Avatar
No Issues. 67k miles on '99 996. Needed a clutch so had a LNE IMS solution and a new RMS put in, just in case!
Old 07-02-2013, 11:16 PM
  #189
aviography
aviography's Avatar
Your car should be dual-row bearing, which is not a candidate for the IMS Solution, which is only for the single-row 996.2 and 997 cars.
Old 07-03-2013, 05:07 PM
  #190
KrazyK
KrazyK's Avatar
To you guys posting that your old bearing "looked perfect". Are you saying the seals are intact and oil was not in the bearing,,,,, or the seals are intact but failed because the bearing and tube had oil in them? Just trying to clarify because my bearing looked fine but bearing and tube were full of oil because the seals had obviously failed. If failed seals are added in the mix the failure rate just jumped from 9+% to about 50%, probably more.
Old 07-04-2013, 02:03 AM
  #191
5CHN3LL
5CHN3LL's Avatar
1999 C4, 58K miles, replaced dual-row IMSB with LN bearing as preventive maintenance during clutch replacement. Other than being full of stinky intermediate shaft oil, the OEM bearing appeared healthy. Both seals were in excellent condition, and the bearing had no play.
Old 07-06-2013, 04:37 PM
  #192
Grey Guy
Grey Guy's Avatar
2002 C4S, manual, 127.5k miles. No issues. I've kept up with the recommended service intervals.
Old 07-20-2013, 04:25 AM
  #193
gsessler
gsessler's Avatar
2002 C4 Cab, manual, owned since new, 58k miles, RMS replaced 14k, no IMS issues
Old 07-23-2013, 01:14 AM
  #194
dgjks6
dgjks6's Avatar
1999 c4 cab 6 speed
Went to have the IMS changed at 38,000 and found it had almost failed. Metal shaving throughout the engine. Still deciding on rebuild or try to flush it out.
Old 07-27-2013, 02:15 PM
  #195
deoslo
deoslo's Avatar
I had a new 2009 factory replacement put in my 2002 C2, after much research no one could tell me if Porsche fixed the problem in the new engine so I finally decided to go ahead and have it replaced. when my mechanic went in to do the retrofit he found that it couldn't be done and the bearing had been beefed up and should be good to go. anyone have any thoughts on this?
still confused!
Quick Reply: IMS bearing failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2 failure mode)
