996 Forum 1999-2005
Measured my crankcase vacuum...@ ~6" water
Old 01-28-2013, 03:16 AM
Ahsai
Ahsai's Avatar
Default Measured my crankcase vacuum...@ ~6" water
I read it in Excellence mag or somewhere that the crankcase pressure should not exceed 9" H2O, otherwise the AOS may be faulty and creating too much vacuum. Mine measured ~6" H2O.
I used a clear tube partially filled with engine oil instead of water in case it gets sucked into the engine. Then I adjusted for specific density. Now that I have a baseline for future reference
***Update: Normal value should be 4-6" water. See the article here
Name:  Drawing1 (Small).jpg
Size:  21.4 KBName:  IMAG0924 (Small).jpg
Last edited by Ahsai; 01-28-2013 at 03:30 PM. Reason: Added link to the relevant article
Old 01-28-2013, 01:47 PM
Black_on_black
Black_on_black's Avatar
Oil has lower density than water, hence it makes sense that the column will be higher. You can search online for density difference - the height column will be proportional. I bet it's 0.8x lighter, hence 6" oil equals roughly 5" water...
Old 01-28-2013, 01:49 PM
Ahsai
Ahsai's Avatar
Yes, that's exactly what I did - "...Then I adjusted for specific density..."
I measured ~7" oil pressure.
Old 01-28-2013, 02:35 PM
Byprodriver
Byprodriver's Avatar
I had Tony Callas of Callas Rennsport, who may have written the article you read, measure mine with a manometer he uses on BMWs. My rebuilt engine had 5 inches at idle, which Tony said is ideal.
Old 01-28-2013, 02:38 PM
Ahsai
Ahsai's Avatar
That's it! I knew I read it somewhere...just escaped my mine who wrote that article. Thanks for the 5-inch data so now I know I'm not too far from it at ~6" H2O.
Old 01-28-2013, 02:41 PM
Byprodriver
Tony writes a column for Panarama & Excellence.
Old 01-28-2013, 05:17 PM
kromdom
kromdom's Avatar
good info, thanks for sharing. This method was what I had in mind for later:LINKY>>>> http://www.renntech.org/forums/tutor...for-a-bad-aos/
Old 01-28-2013, 05:18 PM
Black_on_black
I must have read too quickly then, my bad. Carry on...
Old 01-28-2013, 05:27 PM
Ahsai
Ahsai's Avatar
http://www.youtube.com/watch?v=axBNu...layer_embedded
Yea, saw that before but decided it's too much work and functionally no difference anyway. Not sure what's the pink stuff they put in the tube but I would hesitate to use anything other than engine oil. The reason is if the suction is too much (you have no way to tell ahead of time before you measure it), the engine will suck in whatever solution you put in the tube...Engine oil works great. Just need to multiply whatever you measured by the the specific density of the oil (0.845 for Motul x-cess 5w-40 in my case) to get the reading in water, as explained by black_on_black.
I figured. It's good to explain to other people anyway
Old 03-17-2021, 08:04 AM
labdag
7th Gear
labdag's Avatar
Is there an update whether the problem was fixed?
Old 03-17-2021, 01:26 PM
dougn
dougn's Avatar
I've only got 4 inches and I'm NOT happy about it!
Quick Reply: Measured my crankcase vacuum...@ ~6" water
