996 Forum 1999-2005
DIY: Fixing headliner rattles
Old 01-21-2013, 04:20 AM
ccaarmerciill
ccaarmerciill's Avatar
Default DIY: Fixing headliner rattles
This is a really easy job, and requires just a screwdriver and some strong double sided 3M sticky tape, or felt tape. Having panel removal tools makes it easier and can be safer to take off some of the panels but it's not required.
1. Start by removing the coat hook on the B pillar. It will just pop right off, and shouldn't require too much force.
2. Unscrew the phillips screw, that secures the top of the B-Pillar panel in place.
3. Remove the A-Pillar Panel, It should pop out as well.
4. Remove the C-Pillar panel partially. You don't need to remove the entire back towards the engine, just remove a few clips so that you can work with the headliner.
5. On each side of the headliner, with the panels removed you will see little hooks holding the stretched headliner. Carefully pop the headliner out of each of these hooks.
For the next portion of this, you'll have to climb into the back seats.
6. The rear portion of the headliner secures into place by a plastic panel with little hooks. Carefully pull on the rear end of the headliner out towards the rear window to release it. The panel looks like this under the headliner:
^ As you can see... the factory "tape" that appears to be there to keep the plastic from rattling doesn't hit all of the plastic parts sticking out. Must have been a Friday at the Porsche factory the day my car was built.
7. A little ways back from the sunroof, you will see a metal rod that clicks into place on each side, that keeps the headliner from sagging. Slide the rod back to remove through the slit on each side.
Once this is all completed, you will have access to almost the entire roof panel, from the sunroof back. From there you can diagnose where your rattles and squeaks are originating from. My car had a few areas already addressed, whether it was done at the factory, or from a previous owner... it definitely had a few areas where felt was applied. One area that I knew for sure was creating a rattle was the rear plastic panel that attaches the rear headliner to the roof panel. I could see where the plastic was rattling onto the metal, by spots where the paint was rubbed off, also by tapping on it while it was secured re-created the same sound I'd always hear over bumps. I might have gone a little overboard with the sticky tape, but I didn't want to put everything back on, to still hear rattles. Below are pictures of where I had to add double sided sticky tape to buffer the loose plastic on metal contacts. (Once again, the source of your rattles may be in a different location, you will have to do some wiggling, and tapping to see where your rattles originate from)
To put everything back together is the reverse of removing the panels. Be careful with the little clips on the panels, as they are definitely a pain if you don't have them lined up perfectly. If one gets stuck in the metal body, you can remove it with pliers, and put the clip back together. This happend to a few of them, and if you look at the clips you will easily figure out how to fix them.
If you have any questions, don't hesitate to ask. It's a very easy job, I regret not doing it sooner as my rattles were very annoying. I still have a few more in the interior, that I'll be tracking down soon.
peterp (12-02-2021)
Old 01-21-2013, 09:12 AM
osteoman
osteoman's Avatar
Default Great DIY
What a great tutorial. I have rattles as well, and can't wait to do this DIY project!
Old 01-21-2013, 09:30 AM
Invius
Invius's Avatar
+1, great write up!
Old 01-21-2013, 10:25 AM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
well done, thanks!
Old 01-21-2013, 10:46 AM
white99c2
white99c2's Avatar
Excellent write up I saved it.
Old 01-21-2013, 11:20 AM
Dan@SCB
Dan@SCB's Avatar
awesome!
Old 01-21-2013, 11:58 AM
alpine003
alpine003's Avatar
Rattles have been quite annoying for me too and I'm quite surprised to see that happen in a relatively pricey car(when new).
Thanks for the write up as it will save me some headaches and some replacement parts.
Old 06-05-2015, 12:18 PM
mike9186
mike9186's Avatar
I just used this DIY tutorial to fix the rattling headliner in my 997. Thanks for taking the time to create this!
Old 01-25-2019, 02:17 AM
anunez0323
anunez0323's Avatar
Default Rear headliners.
[QUOTE=ccaarmerciill;10159708]This is a really easy job, and requires just a screwdriver and some strong double sided 3M sticky tape, or felt tape. Having panel removal tools makes it easier and can be safer to take off some of the panels but it's not required.
Did you use the 3m tape to just cushion the one side or did you adhere the headlliner panel using both sides of the tape. Thank you.
Old 01-25-2019, 10:40 AM
parris
parris's Avatar
Hello guys,
What do you mean with rattles? kind of noise? (sorry for my english)
What I have in the headliner, and I dont know if it is correct, is that, when I open the sunroof (both, tilt or completely open) the headliner waves, like the wind passing between it and the metal roof. No noises here, but it doesnt look normal to me. None of the cars that I have had previously with sunroof have done that. Does it happen also in yours?
Old 01-25-2019, 10:46 AM
DBJoe996
DBJoe996's Avatar
Received 1,085 Likes on 697 Posts
Originally Posted by parris
Hello guys,
Mine does the same thing. The headliner looks and seems tight, just waves a bit with the window cracked. I ignore it.
Old 03-29-2019, 05:29 PM
NIKAS
NIKAS's Avatar
Great thread. Thank you ccaarmerciill!
Old 03-30-2019, 05:02 AM
dan_189
dan_189's Avatar
Mine does this as well, just an airflow thing I think
Old 03-30-2019, 08:49 PM
Christopher28
Christopher28's Avatar
I just have my girlfriend ride in the back and hold it up. Sometimes I forget to let her out.
Old 03-06-2020, 02:42 PM
merlot
merlot's Avatar
Does anyone have the pictures from this DIY? They are no longer showing for me - unless my work is blocking them. Thanks!
Quick Reply: DIY: Fixing headliner rattles
