996 Forum 1999-2005
PSE ( Porsche Sport Exhaust) 996
Old 04-01-2012, 06:00 PM
rdgibby
2nd Gear
rdgibby's Avatar
Default PSE ( Porsche Sport Exhaust) 996
Does anyone have any experience with a SPE button problem?
I can't select the quiet mode . The only way I can is before start up hold the switch button and turn the ignition on. This gives me the light in in the switch and it will be in quiet mode when the car is started. That is the way it stays till the next start up.
To me it sounds like a switch problem, all vacuum connections are good and vacuum switch appears to be good.
Old 04-01-2012, 09:20 PM
SnapSlap
SnapSlap's Avatar
I wish I had that problem damn you quiet mode from 30-45.
Old 04-01-2012, 09:26 PM
Barn996
Barn996's Avatar
That's a good thing, right?
Old 04-01-2012, 09:53 PM
vange_c4s
vange_c4s's Avatar
hi,
mine starts in sport mode. when i need to be quiet in the morning i turn the key on, then press the pse button, while the oil check samples, then start her up and its quiet. after i am off the street i press the button again for regular sound. not sure if this helps?
Old 04-01-2012, 10:03 PM
Dharn55
Dharn55's Avatar
There is a relay in the system and it sounds like that may be the problem.
Snap slap, you know that if you disconnect the lead to the speedometer then you will not have the quiet mode between 30 and 45. On my car I never connected this lead when I installed my PSE.
Old 04-02-2012, 02:36 AM
SnapSlap
SnapSlap's Avatar
doug - got a link to a DIY?
Old 04-02-2012, 04:26 AM
NZ951
NZ951's Avatar
I would kill for PSE!
Old 04-02-2012, 09:30 AM
jfintexas
jfintexas's Avatar
That's what that is! I have been growing increasingly suspicious when my car was noticeably muted in 2nd gear. This forum is just a gold mine of information. I think I am interested in disconnecting that speedo relay. 2nd is my favorite power band and I am missing out on that glorious exhaust note!
Old 04-02-2012, 11:26 AM
dotframe
dotframe's Avatar
I did this mod within 2 weeks of owning mine My wife thought I had lost my mind, opening up that relay to pull out the resistor, lol.
So much better now.
Old 04-02-2012, 12:22 PM
Mickey356
Mickey356's Avatar
Uhhh, little help here!
I just thought it was "the way it is", with regard to the quietness in 2nd.
What is this relay disconnect thingamajiggie you speak of?
How can I get that awesome sound all the time? I LOVE the sound my PSE has when it's growling.
Old 04-02-2012, 06:27 PM
Dharn55
Dharn55's Avatar
What is the old saying, if you can't find it here you can't find it anywhere!
A little light reading on this subject.
http://www.renntech.org/forums/topic...ools-required/
http://www.renntech.org/forums/topic..._fromsearch__1
File Type: pdf
File Type: pdf
kc0433 (02-27-2021)
Old 04-02-2012, 07:34 PM
Mickey356
Mickey356's Avatar
Thanks, Doug, you're the best!
Old 04-02-2012, 07:51 PM
SnapSlap
SnapSlap's Avatar
Thanks guys!
Old 04-03-2012, 08:09 PM
redridge
redridge's Avatar
I put a little micro switch between the speedo signal and the relay.... with a flick of the switch, you can have the speedo option or not.
Old 04-03-2012, 08:24 PM
Dharn55
Dharn55's Avatar
I like redridge's idea. May have to go back in and install the wire with a switch.
Quick Reply: PSE ( Porsche Sport Exhaust) 996
