996 Forum 1999-2005
PSE ( Porsche Sport Exhaust) 996
Old 07-03-2016, 11:45 AM
  #31
Ponchobroke
Ponchobroke's Avatar
Thx, I'll start hunting
Old 07-04-2016, 03:18 PM
  #32
nemo9xx
nemo9xx's Avatar
In this picture you see every parts included with the PSE option.
Old 07-19-2016, 07:28 PM
  #33
TheMystro
TheMystro's Avatar
Bump for this thread. This is a must mod for factory PSE cars. Worked like a charm on my C4S. Having the beautiful sport exhaust mute at 30 mph is like some sadistic hitting mute on your favorite song. This stupid Euro noise restriction should never be on any NA cars but it is. Just did a 5 minute mod by snipping the one side of the red diode and bending it up and that was all it too. No fault codes, my quiet button on the dash works as designed but no more 30-40mph sport exhaust muting. Funny thing is, in the states you want your exhaust to sound nice at 30 mph, that's where most of your cruising is done with your windows down when you can hear it.
Old 07-19-2016, 09:37 PM
  #34
Triple Black
Triple Black's Avatar
Is this 30 to 40 mph muting thing just for the C4S? I don't have any such muting on my C2.
Old 07-19-2016, 11:39 PM
  #35
TheMystro
TheMystro's Avatar
It is on all 996/997 factory PSE.
Old 07-20-2016, 11:36 PM
  #36
DinoSC
DinoSC's Avatar
Like triple black I have a 2004 C2 with the PSE from the factory (option XLF) and on my drive to work this morning I tested 2nd and 3rd gear: it doesn't go on mute between 30 and 40 mph.
Old 07-21-2016, 01:47 AM
  #37
Triple Black
Hmmmm. Not so for mine. Wonder if the PO did the mod.
Old 07-23-2016, 08:45 AM
  #38
Domv8206
8th Gear
Domv8206's Avatar
Hi guys. I've been wanting to upgrade to a pse. I have a 2000 996c2. I found one coming off of a 2015 Carrera S. 991.
Just have a few questions. Is it a direct swap? Are there any modifications that have to be made? How much should I pay to have it installed?
Any help is appreciated.
Old 07-23-2016, 01:13 PM
  #39
Triple Black
I could be wrong, but I doubt that a 991 exhaust will fit a 996. I'd be sure to check it out before buying it.
Old 07-29-2016, 09:17 PM
  #40
Domv8206
8th Gear
Domv8206's Avatar
I contacted porsche to check compatibility and your right. It's not compatible. Thanks
Old 03-20-2017, 03:19 PM
  #41
mark_schnell
mark_schnell's Avatar
Default Thread necromancy here...
Originally Posted by Dharn55
What is the old saying, if you can't find it here you can't find it anywhere!
A little light reading on this subject.
http://www.renntech.org/forums/topic...ools-required/
http://www.renntech.org/forums/topic..._fromsearch__1
Thanks for this!
I want to install the button on my dash for an aftermarket system. This could help with the install greatly, especially the part numbers...
Old 09-09-2017, 10:22 PM
  #42
Vfrealtor
Vfrealtor's Avatar
Hello All,
Slid under my dash right above the fuse box panel. Found the relay area and the "asskklagganenngben" relay, wiggled it out and grabbed my precision screwdriver set. Upon further review of the black relay box, it looks as though someone mess around with the pry areas. Finally got the cover to pop open, thus exposing the diodes and motherboard. The "red" diode Pin 1 was already cut for me! I figure the previous owner stumbled upon this hack and saved me some time. Score!!! I am now wondering what other goodies or gremlins previous owner left for me to discover. My PSE button does not light up, so there is always the sound of the PSE in every RPM band. Thanks everybody.
Old 09-09-2017, 11:43 PM
  #43
Net_fix
8th Gear
Net_fix's Avatar
Default Pse 996
Hi
I have a 06/2002 996 c4 cab, manual, that I ordered new loaded, including pse. Mine has not the dash button, is it possible to install it? Regards
Old 09-10-2017, 08:37 AM
  #44
rporzio
rporzio's Avatar
Thanks for the PDF's, good reading! R.
Old 01-03-2021, 02:44 PM
  #45
CharlieBravo
CharlieBravo's Avatar
Bringing an old thread back. Did 996.1 carreras have the option for a sport exhaust? If so did it still have the nested quad tip look?
Quick Reply: PSE ( Porsche Sport Exhaust) 996
