996 Forum 1999-2005
what is this hose
Old 12-31-2011, 02:16 PM
sportlineguy
sportlineguy's Avatar
Default what is this hose
I have found a clear plastic hose/tube near the battery that I think is the battery vent but it is not hooked up as the current battery is sealed. Should I replace it with a vented battery or another sealed battery? Pic should help sort this out.
It is on a 2001 996.
Old 12-31-2011, 02:52 PM
Goldenwarrior1
Goldenwarrior1's Avatar
It is the battery vent. Someone replaced the battery with a non vented battery. Not a good idea IMHO...
Old 12-31-2011, 02:53 PM
jyoteen
jyoteen's Avatar
that battery is vented. See the nipple in the back (middle). Just the vent hose isn't connected.
Old 12-31-2011, 03:52 PM
Goldenwarrior1
You have better eyes than me, I missed it!
Old 12-31-2011, 06:06 PM
fpb111
fpb111's Avatar
Gw,
Curious, why not use a "sealed" battery? Seems like an AGM or Gel battery would have less chance of sloshing acid into the nooks and crannies of the bulkhead.
Old 01-01-2012, 01:03 AM
sportlineguy
The battery is sealed and no vent - looks like possibly a nipple out the back but nothing there. When I replace it will look at both vented vs non-vented. Is there really any difference overall?
Old 01-01-2012, 08:46 AM
Goldenwarrior1
When charging a lead acid battery a portion of the charging current, that which is required to maintain 100% percent state of charge, will electrolyze water thus generating free oxygen and hydrogen gas to be vented from the battery. The mixture of the gases are explosive which is why they are vented from the car. VRLA (Valve Regulated Lead Acid) and AGM (Absorbed Gel Mat) batteries are sealed and therefore do not require servicing or venting. If you use a sealed battery then you do not need a vent tube. Because the wet cell lead acid batteries are the cheapest I suspect Porsche engineers went that direction simply to save money. Kind of like the infamous IMS bearing...
Old 01-01-2012, 02:35 PM
fpb111
fpb111's Avatar
I have been very impressed with the AGM batteries. I had them (two for early 911s) in my '72 hot rod for 12 years with no problems. I use a battery tender during storage. Both of the early cars, 1970 & '72, needed new battery boxes welded in due to battery acid corrosion.
I have a 1998 BMW R1100RT that has a 10 yr old Westco AGM in it. Still starts that high compression twin with little problem.
My 2003 C2 Cab needed a new battery when I bought it so I got a Braille AGM. We will see if it gives similar service in the newer car.
Old 01-01-2012, 04:34 PM
fbgh2o
Odd Posts
fbgh2o's Avatar
Default Is this also a vent hose?
I discovered this one today while changing the cabin air filter. I guess it is a battery vent hose, but I am not sure. It appears to go exit into the wheel well and has a 90 degree elbow on the other end.
Could it also be a sunroof drain?
Old 01-01-2012, 04:45 PM
street rod
street rod's Avatar
Looks like the battery vent. Mine has the 90 degree on the end also. My new battery had a differnt type of vent hole and I had to replace the elbow with a different fitting.
Old 01-01-2012, 04:52 PM
Goldenwarrior1
Looks like a battery vent to me and doesn't appear to have been used for some time! Your sunroof drain is larger diameter.
Old 01-02-2012, 09:27 AM
relinuca
relinuca's Avatar
I think the battery vent hose definitely serves a useful purpose in the case of vented batteries, which most of us have. To wit: if you slightly over fill the cells with distilled water (which is easy to do), then the excess will be expelled via the vent hose to the ground...out of harm's way.
In other words, the venting function applies to both gas/fumes and fluid.
relinuca
Old 01-02-2012, 10:46 AM
SSST
SSST's Avatar
AGM batts should do fine in these cars. I use them in my boats and they will take a heck of a beating.
Quick Reply: what is this hose
