2001 996 headlight washer problem
It seems that only the rightside washer jet sprays when I try and wash the headlights - this has the lintronic headlights. Nothing comes out of the left side.
Where should I start to diagnose this - shlould I remove the left headlight and then washer to see if clogged or ? Pump works so I'm thinking something in the lines or nozzle? This is not the pop-up washer from 2002 on.
Your ideas?
Your ideas?
The hoses can come loose I would check that 1st.
head light washers
I agree...pull the headlight out (see owner's manual for instructions) and then activate washers. The washer units are feed by a single line from the pump. So a clogged or leaking nozzle is a good guess.
relinuca
relinuca
